Fuel tube and Grommet issue...Need HELP!
66plysat
2:40 AM
Rancho Cucamonga, Ca.
I'm changing my older custom tank to a stock tank and NOS sending unit on my 66 Satellite. I can't figure how to insert the fill tube into the grommet then into the tank. I installed the grommet into the tank then tried to insert the filler tube, won't go. I tried to put the grommet on the tube the force it into the hole in the tank, won't go. I siliconed the grommet and the tube and the hole of the tank to help things, didn't help.
Is there a secret to putting the tube, grommet and hole together? HELP, please!
The grommet goes in the tank, the tube pushes in. Silicone grease for sure.
Sounds like 1 or 2 of the 3 aren't oem size.
If it's an after market fill tube that maybe a/the problem. A few guys have complained about them. You could put a WTB ad if lubing your part does work. Dish soap works also.
I can't tell which grommet you are using, from the picture. There are two styles that will work. Most of the ones that are sold now are what I call the double seal. The originals were what I call a single seal and were reproduced at one time, and may still be. The original style is easier to install, but more prone to leak if everything is not lined up correctly. If either were easy to go in they would probably leak. Use plenty of lubricant like WD40 on both the grommet and the tube. When it goes in, it's even harder to pull out if you go to far. The freshness of the grommet makes a difference also as they get hard with age. Best of luck.
Yes, I used WD40 to get mine together. I may have also used some silicone grease on another one.
I had this problem on my 64 Fury. Finally, after careful measuring and comparing with the old grommet, I determined that the new grommet I bought off of Ebay was made too thick. Apparently some of these "no name" Ebay parts are just made wrong. I got a different grommet, and was able to assemble it with no problem. I think the last grommet I bought, which worked came from DMT. (IIRC)
@66plysat, Here is my thread on what I had to do on my 64 Fury. - With that, I do NOT recommend the Inline Tube grommet that I used on the 64 to go in a 66/67 style tank. I tried one on my 67 Coronet, and after a week it started leaking badly. The way the 66/67 tanks are made, the filler grommet is down low, and stays immersed in gasoline, unlike the 64 which has the filler tube at the top of the tank. Apparently the rubber composition was unable to handle staying immersed, and it softened and leaked. I replaced the Inline Tube grommet in the 67 with one from DMT, and it has been holding fine.
New fuel tank and filler tube. The grommet is TOO tight to insert the tube!
I highly recommend installing the tube prior to installing tank.....just twist it down a bit and adjust it when strapped in. You will find it impossible to get that neck into the hole under the car. Lube....or no lube. WD 40 is great for a bit of lube that will wash out into the tank. Hit me up in PM is more info is needed.
I've read several recommendations for the grommet from DMT, so I ordered one. Hopefully with the new grommet and some lube it will fit. I'll let you know. Thanks for all the comments. (but I don't think I'll be eating more spinach).
On my 65 Belvedere wagon there is no way to install the tube first. It was a PITA to get the tube in from the top. Some lubrication was needed. I also sanded the lower filler tube to clear any scuffs and what not and it did eventually got in.
I know this is an older thread, but I'm going through this nonsense with my 66 Belvedere (yes, I lubed the filler tube and grommet and even applied heat with a heat gun to the grommet). I ordered my tank and grommet from Classic Industries. The filler tube will NOT fit into the new grommet when the grommet is installed in the tank. I measured the I.D. of the new grommet from Classic Industries at 1.9". I ordered another grommet from DMT which lists their grommet as having an I.D. of 2.0". I imagine that will resolve the issue. I'll post the results when it shows up.
Classic probably sells OER brand. I had the same issue years ago with that brand. Now I use the '70 & up grommets from DMT on every car that they'll physically fit in. I just installed my latest one in a 1970 Roadrunner with a new aftermarket tank and fill tube. It installed without effort.
Mopar B Body 70 & E Body 70-74 Fuel Gas Tank Grommet 3404182
From their description:
This grommet is made for us to our specifications and materials. We are not a reseller of a product this important that we don't know the origin or real specs.
1970 70 1971 71 1972 72 1973 73 1974 74 AAR, Barracuda, Challenger, Cuda, T/A
1970 70 Charger, Coronet, GTX, Roadrunner, Satellite
Note: This is the correct grommet for 70 B bodies. Our other more common 64-74 grommet will also work and is the exact same physical dimensions but this correct grommet has an extra sealing lip that was added by Mopar for all 70 and later models.
Also, bulbous side goes INSIDE tank. See reference picture.
Dimensions - 2.900" OD, 2.350" Groove OD, 2.000" ID, 1.150" Ht
Mopar part# 3404182 (Old DMT part# EBX7074TG01)
Materials
Just like OEM.
Just did this myself classic industries one I could not get to fit for anything. Ordered DMT and it still took some umph to get it in there but it went in and worked nicely. The DMT one will solve your issue.
So I ended up using DMTs part # 2203472 2880481 which was listed for 64-69 B bodies. It fit perfectly into the tank with no issues getting the filler tube in. That 1/10" extra on the I.D. did the trick.
