Considering aftermarket front suspension? Learn about geometry in this video
dvw
8:58 AM
waterford mi
I've made my feelings known about aftermarket geometry many times here. This is a great video. Does Kevin have high tech tools? Nope. But he understands suspension very well. This just gives you a good insite of what could be expected when you go this route. I've done suspension work for over 50 years. Never used aftermarket stuff that has been correct out of the box. Watch and learn. If you have questions ask me.
Great vid, thank you for sharing. I'm glad I decided long ago to stay with my Mopar oe based stuff. Of course its not perfect, but can be dealt with.
that guys videos are awesome.. have learned soo much from him over the years
I'm surprised if that is a kit how bad that upper ball joint angle was.. at extension that is some serious pressure trying to pop it apart. Seems the uppers could be made with a bend between the heims and ball joint to bring them more in line with the knuckle
Either the entire K frame and lower supension was mounted 1"-2" lower on the stock rails? Or the upper arms weren't even close to the correct dimension. Everytime I've seen one of these front end "Kits" it's the same reoccuring theme. The geometry wasn't thought out.
That upper ball joint angle looks horrible.
Thats pretty bad, having to fix geometry that should have been correct to begin with.
I'm guessing that spindle is just too short.
Could be as well. To be honest I didn't pay attention if the spindle was a Mopar based design or Mustang II. For sure that could be the issue. You would think if they sold this stuff it wjould be somewhat close. I did a 64 Fury' for a customer with QA 1 stuff. Had to space the outer heims with close to 1 1/2" of spacers. That's nuts.
