Tachometer stopped working and stuck at 1200
Charger Fan
8:14 PM
Jupiter FL
Posted this in the electrical section but wanted to get more exposure to some help diagnosing so here goes. I have taken the plastic Rally dash bezel out to repaint and redo the wood grain. It’s taking me at lot longer than expected because to many other distractions. Thus I hadn’t started and run the engine in awhile so I started the car up only to see the tach move up very slowly and then stopped. Prior to removing bezel the Tach had worked with no issues. While the engine was running the tach didn’t react to the throttle pumps. Then after shutting engine down the needle stayed where it where it had climb to about 1200 (see photo). I made sure there were no metal to metal contact between back of instrument cluster and frame work behind dash before starting the engine. The two connectors that go to the tach (blue and gray wires) are still attached. What would cause the tach to do what it’s doing? All other gauges worked fine. Any experience would be appreciated.
Is the needle getting caught by the plastic bezel, if not it might of gave up the ghost.
How did you get the bezel off without removing the gauge cluster as a whole
That must have been fun , with all those screws laying on your back Yikes
I would have dropped the steering column and removed the gauge cluster as a whole
Is it a factory installed tachometer ? What year B Body 71- 74 Looks original or did you add it yourself
If so follow your signal gray wire , depending upon year on how it either goes thru bulkhead connectors to the negative side of Ignition Coil
