WTB 1966 Satellite trunk trim panel fastener hardware
AR67GTX
1:26 AM
Arkansas
Feedback: 16 / 0 / 0
Looking for around 4 of the threaded stud and nut sets used to secure the trunk panel trim on a Satellite or Belvedere II in 1966 to replace a few of mine that are pretty far gone.
Thank
Are they the same as 67? T-shaped head to slide into the track on the panel. I know I have some extra studs. Not sure about nuts.
It’s been so long since I’ve had my trim off my 67 I can’t remember if they are the same. Let me do some research and I’ll see what I can find out.
I haven’t had much luck. I thought I had an old 67 panel in the attic but I must have gotten rid of it. The 67s from eBay photos have an extruded slot the fasteners slide into. The 66 panel has tabs with a keyhole slot in them. I would think the flat head of the 67 stud heads if no larger than .4 inches would hook into them
OK and I would be willing to give them a try. I have quite a few stamped nuts so that’s no problem
I'll take some measurements of what I have. I'll send them to you if they look like they will work
If they look like they will work let me know what it will take to cover cost and shipping.
Not sure how well that would work even with some trimming. If they rotate in the process of threading the nut on they might back out. I think I’ll do some more looking and maybe I can find something to work. But thanks for responding and checking those out.
