All the lifter turn, no tight bores. I'm going to go with it, we'll see but I'm good with it. Here is the cleaned up lobe.
Cam is lubed, lifters are oiled, timing gear is on and lubed. I put the valley pan in place to keep dust out. And here is a pic of the cam card if anyone is interested. Old cam was a Hughes STL-3842, which I was running prior to the head porting. I liked it, and I can run the same springs. This one has more duration which hopefully raises the power band a bit. I'm also looking into getting 3.76:1 rear gears (about the best I can do with the current 741 rear).
