rpmmachineco
So I'm building a low buck hot rod out of an old 63 dodge 330 wagon. I did not realize until today that it has the tapered axle rear.. Its an 8-3/4. I searched the web a little and really couldn't find a definitive answer to my questions so here goes, I'll ask you guys. I have a good 3rd member from a later 8-3/4 the 742 housing with a posi unit. and 3.23 gears. Is this a direct swap in my housing? 2nd- most say to replace the rear, that it will not hold any hp. I'm building a 440, I believe it should make 450hp, I know the org, 62-63 max wedge cars used this rear didn't they? Also, if I do replace the housing with an 8-3/4 flange axle rear, what rear should I be hunting from what model car? Some say look for an A-body rear others say late model B body rear is a direct bolt in? I just want to make sure if I really need to swap the rear, and If I do, what will make the easiest bolt in swap? Thanks guys.
