Line lock brake line location?
threewood
3:17 AM
SE NM
I bought a B&M line lock for my 69 GTX. From my master cylinder I have 2 lines out, both go to distribution block. From the distribution block, two lines exit to frt right and frt left brakes, third line exits to rear brakes.
I thought this should be mounted after the distribution block but I can't because the front lines aren't tied together.
How has everyone else installed theirs?
I have mine mounted in the drivers side wheel well.
It is plumbed after the proportioning valve.
It's mounted on the other side of the valve hidden away.
following along. debating on one for my Charger.
I’ve got a Hurst line lock too, but not yet installed. As I understand it, you block off one of the front brake lines coming out of the distribution block. Run the single front brake line into the line lock. Coming out of the line lock, you install a “T” that lead to both front brakes
That is an interesting idea. I'm not sure I have the room down there to cut and flare lines with the engine in place....
This was on my A body, but same idea. I bought a bracket for a Chevy distribution block. In this case I mounted both the distribution block and line lock on the same bracket.
I used to own a 57 Chev 3 ton. Used it to tow and deliver boats. I put the line lock on the back wheels to secure the truck on a launch ramp. Also used wood chocks.
This is of no use to you folks at the drag strip.
Well, it can be. On my previous cars with automatics, I installed the line-lock on the rear lines and backward. That way I could engage the line lock, then use the brake pedal to modulate pressure to the front brakes.
I installed mine by cutting into the line out of the rear resevoir (which is for the front brakes) and installed the unit there - before the distribution block. Worked like a charm.
I've heard of doing it that way. Usually to enable long rolling burnouts to show off.
That's what I would do. And have.
This would certainly be the easy way to go.
I did the same on my GTX, mounted on a plate riveted to the inside of the frame rail. The plate also holds a Wilwood adjustable proportioning valve.
I have mine mounted to the firewall under the master cylinder mounted by a custom made bracket that I made that is retained by the lower two master cylinder nuts so that it is not really all that visible.
I opted for the reverse install on the rear brake line. I just couldn't break open the front brake line from the master to the proportioning valve. Easiest spot was in front of the leaf spring mount.
The kit came with an indicator light. Where does this get wired in? I'm guessing between the switch and line lock? The instructions are pretty poor. Thanks.
The kit came with an indicator light. Where does this get wired inThI'm guessing between the switch and line lock? The instructions are pretty poor. Thanks.
View attachment 1857400View attachment 1857401View attachment 1857402
I wired a DPST toggle swich under the dash. One side sends power to the line lock, the other side grounds the factory brake warning light circuit which turns on the light. I tied it into the parking brake switch wiring on the pedal assembly.
All wired in. The switch is on the shifter, the indicator light is under the column and wired between the line lock and switch. My wife was an excellent help pushing the brake pedal to help bleed the brakes. No leaks.
Took it out and it seems to work good. I really have to hold the brakes to keep the front locked up to keep the car from creeping ahead. But smoky burnout accomplished.
