Found my build sheet! Need help softening paper
6:31 PM
Oregon
So I just found my build sheet to my 68 Charger Rt. When I bought the car, I was told it wasn't there. Turns out It was stashed above the heater box.
The paper itself is very brittle and was falling a part as it was being handled very carefully. What is the best way to soften the paper to make it malleable? TIA
Humidity I think would help in small doses of vapor. If you try it use a part that has no info. I'm talking very little to start with. Might want to google how to save dried out paper documents.
This might sound crazy but aunt always put a slice of bread in the container with her cookies or brownies. It kept them moist. Perhaps that would work. The moisture in the bread would migrate to the paper. Perhaps.
It seems that not a lot can be done..
Here's what the library of Congress has to say about it:
"Once paper becomes brittle, very little can be done to strengthen it so that items can be safely handled. The accepted traditional method is to line a document with thin, stable, translucent archival grade paper such as Japanese tissue, using approved stable and reversible adhesive"
About the micowave heat a wet rag heat the rag first then put the paper in. the fan will blow it around. Might want to have tweezers with a wide tips to handle pieces.
I hear ya. Mine is still in the back seat, but the paper is totally adhered to the seat springs and crammed up in the corner. It's too fragile to pull out. When I pull the springs, the paper comes with it and starts to tear. Not sure how I'm gonna remove it without major damage...
its like removing a stamp, or steaming an envelope open...
Wonder if dental floss no steam or with steam. Start in a no info area of BS. Maybe you can pull springs away from foam, maybe it would be a disaster. Mine came tight out, but my car was only 25years old.
Thank you all for the great input!
I ended up using my son's cool air humidifier and put a light amount of moisture into the zip lock bag ( 5-7 seconds worth) I let it sit for about 10 minutes and it was super pliable. I was able to easily unravel it and lay it some what flat. After a couple minutes it dried back out before I could get laid out all the way.
My son had a slinky hose, so I redirected the mist through the hose to the paper and it immediately laid back flat. I put the zip lock bag over it and put a stack of books to keep it flat.
I found some 12x12" acid free magnetic photo album inserts to put the broadcast sheet in. I know it may not be ideal but it was the only way I could piece it back together without it moving all over the place. Fortunately I am able to read most of it after using Qtips to brush the dirt away. Thankfully I can read the sequence, shipping and sequential number.Not sure if being above the heater all those years was a good thing or not.
Thanks again!
