I'm cleaning up the original motor mounts on my 70 Charger 383 HP. They look ok to me, but should I be disassembling and replacing the isolator? Is that a thing or will my 55+ year old mounts be fine?
			What's a restraint look like?Run what you have and install a restraint on the drivers side mount.
Sorry for the ignorant question, but can just the rubber isolator part be replaced or is it an all or nothing?OR —- they are inexpensive —- this is the perfect time to just go NEW —- once for life —- and be done with them…..
It depends on how you look at it. Yes, just the rubber isolator can be replaced, but it comes with the metal plates attached. The part that attaches to the block can be kept and not replaced.Sorry for the ignorant question, but can just the rubber isolator part be replaced or is it an all or nothing?
Thanks - saw them mentioned as junk several times when I searched through the forums for info.Only thing I will add is.
Do not purchase [ Anchor ] brand mounts.
They are cheap junk.
