Door Window Lift Bracket Install Help
penstar pete
11:44 AM
New Jersey
On my 68 Charger the nylon rivet that holds the window lift bracket to the glass has lots of play. I found a kit on CI, but I'm not sure how to change it.
I watched a video, and one guy said there is a bushing type of piece that the nylon rivet goes thru and it has to be crushed with a C clamp. He also tells that the original window rivet with the bushing is not available anymore. Then other videos show someone just pushing it thru w/o crushing it.
Also not sure what the other parts are used for. Any help would be appreciated. Thank you
Check out a video by Angel Garrido. He did two videos on his Baracuda window restoration on YouTube.
