- 12:04 AM
- Jul 17, 2008
- South Jersey USA
Now you'll always know where it is!
maybe the missing 10mm socket is in there
Probably not. It's not metric.maybe the missing 10mm socket is in there![]()
Probably not. It's not metric.![]()
I like hex key, one less syllababble to remember...
That works also.I like hex key, one less syllababble to remember...
Not very often.....only a few hundred times.did I ever mention Torx sucks?
Not very often.....only a few hundred times.![]()
Torx is Torx..... that's it.what plural torx anyway?.......... torxes? torxi?
And the most inportant detail, Allen was a brand name. Like a Crescent wrench or Kleenex if you may. It's actually a hex key.An Allen wrench is a driver tool used for turning boltsor screws that have internal hexagonal sockets.
They are usually made of hardened steel hexagonal rods with blunt ends that fit into equally sized screw sockets. These hexagonal rods are bent to 90º, forming two sides of unequal length, like the alphabet letter “L”.
The tool is rotated by holding it with its long handle, producing a greater torque at the tip of the shorter handle. Allen wrenches are designed according to the size of the socket and are manufactured with very tight tolerances. These tools are commonly used to fasten hex-type screws to wood, metal, and even plastic.
Following are the types of Allen wrenches:
- L-style allen wrench
- T-handle allen wrench
- P-handle allen wrench
- Flolding hex
- Ratcheting hex
- Torque wrench
- Allen screwdriver
- Ball hex
- Adjustable allen wrench
- Combination allen wrench
- Open-end allen wrenching
- Socket allen wrench
- Crowfoot allen wrench
Kleenex would go well with @eldubb440 's punched lasagneAnd the most inportant detail, Allen was a brand name. Like a Crescent wrench or Kleenex if you may. It's actually a hex key.
You need some of these. That'll mess with them.Kleenex would go well with @eldubb440 's punched lasagne
I'm installing some Rivnuts with Molybdenum anti-seize grease and Security Torx screws to secure a piece of acrylic over my trailer number plate, Registration label and WOF (Safety Inspection) sticker this weekend. Some sneaky bastage wandered on my property and ripped off the WOF and Rego label......so I plan to slow them down now.
Security Torx ought to cause them grief.![]()
Snake-eye screws are good also - we use them in factories on switchboards - because unqualified staff start fiddling where they shouldn't.You need some of these. That'll mess with them. View attachment 1859422
