Mariposa Mike
Yesterday I noticed an "oil" slick on the floor beneath the right rear tire and found that it is brake fluid. The 66 Charger is new to me (11 months) but previous owner (deceased) had converted to Dot 5 fluid with a dual reservoir. I have never used it but considered doing so in the past for seldom driven cars. Taking the drum and cylinder off I found one of the cups leaking and one end seized with some corrosion on the bore. Thought this stuff was supposed to stop that. Maybe some moisture got in the system but now I'm wanting to know if I should just go back to Dot 3. Been planning on converting the front to disc and could drain and flush the system if that is way to do it.
Another amazing thing was that I made a rush trip to O'reillys figuring I would have to order the parts and they had two rear cylinders in stock. Got the one on before dark and have a car show to attend tomorrow but I plan to do the other rear next week and probably should do the fronts as well even though I plan to do the conversion later. I've had some issues with adjusting the rear brakes which look new and this might explain that issue. They were tightening up and overheating the drums/rims. Even after backing off the star adjusters they tightened up again. The front brakes were apparently doing the braking for the car and my blaming four wheel drum brakes for less than satisfactory braking was in error. The brake cylinder I removed was frozen so could not have been helping stop the car. Might be the same on the left rear.
Anyone with experience using Dot 5 that has some feedback it would be appreciated or advice for future conversion.
