Data Plate
I had heard that someone has started to reproduce the power steering pump coolers for the power steering pumps can anyone advise who does that? Thanks
I run an inline Power Steering cooler that I pulled from a 84-89 Dodge Diplomat. No problems since.
It has been awhile since I bought fuel lines but there used to be a few companies that made fuel lines, trans cooler lines, brake lines etc,I had heard that someone has started to reproduce the power steering pump coolers for the power steering pumps can anyone advise who does that? Thanks
ABSOLUTELY.......GREAT PRODUCTS.....expensive, which is relative, but the fit, finish, performance is outstanding........highly recommended........just my opinion........
Borgeson, Summit, Dorman has pwr steering coolers from $30-$60.Oh, piss off, Glen Ray.
FOUR hundred dollars? Really?
The cooler got added if the gear ratio was 3:54:1 (Dana 60) and higher 3:55:1 (8-3/4") and greater......my RS23V0A****** with the Super track pack option has the Dana 60 and 4.10 gears from factory.......Mopar only added the PS cooler to cars with 3.90 and higher rear end gears. I have a 71 Cuda, originally 383, 4 speed with 3.90's and it has a PS cooler.
The cooler was part of any of the performance axle packages in 3.54, 3.55, 3.91, 4.10 ratios - Dana 60 or 8.75. Also part of the packages was a 26 inch radiator with shroud and clutch fan.Mopar only added the PS cooler to cars with 3.90 and higher rear end gears. I have a 71 Cuda, originally 383, 4 speed with 3.90's and it has a PS cooler.
Why show pix of the cars????.....they have nothing to do with the PS oil cooler Installation......why not show a pix of the pump and cooler installation???.......although the pix of the green bush behind the pix of the red car, promotes a degree of coolness....don't you think so???....just my thoughts......If you are a drag racer that has skinny front tires and don't turn corners often, you'll probably never need one.
If you are like this guy....
Or this guy....
View attachment 1860194w
Things will be different.
