440 GTX 727 trans/ Car won't move after it sits for a few days
MrDee
8:21 PM
Wisconsin
If I shift to neutral and let the trans pump run, the car moves fine, but if I leave it in park while I warm up the engine, the car wont move until I rev it up a bit. After the transmission warms up, it's fine the rest of the day.
If you get better results in neutral there's no need to warm it up in park.
Problem IS solved. That's just the way it works. Or put an anti drain back in it
Fairly common thing to happen. Convertor drains fluid back into the tranny. Warm up in neutral or get an anti drain back as mentioned above
Converter drains back into the trans. In Park it doesn't pump fluid, put it in N for at least 10 seconds. Before driving.
This is normal operation.
“Very” common with old Mopars.
Transgo makes a different manual valve that allows the converter to fill in park position.
The pump is spinning anytime the engine is running.
Can one assume that if these cars were used daily, like years back when they were "just" cars, that this wouldn't happen?
My wagon does that too. When I light it off, I put it in neutral and let it run for a bit before dropping into drive. My 94 1500 did that too after sitting for a few days. Even with the check valve.
