- 5:21 AM
- Aug 18, 2024
- Virginia Chesapeake Bay
So why do taller gears require a cooler? More RPM? More Heat? What is the engineering logic behind it?
although the pix of the green bush behind the pix of the red car, promotes a degree of coolness....don't you think so???
For those too smart to understand, my car is set up for cornering and handling, not sitting in the garage. I show pictures of myself and my cars as imperfect as they are. The picture was to show most of us, those that aren’t so brilliant that “obvious things slip by them”…that a power steering cooler is an advantage to some but not all.Why show pix of the cars????.....they have nothing to do with the PS oil cooler Installation......why not show a pix of the pump and cooler installation???.......although the pix of the green bush behind the pix of the red car, promotes a degree of coolness....don't you think so???....just my thoughts......
BOB RENTON
As I noted previously.....it's called sensible heat load.....due to increased pumped volume and absorbed entrained heat.......or higher losses.....You answered your own Question. More RPM's create more heat because pump is turning faster. So the cooler dissipates the heat of the liquid.
Not necessarily......depends on rear gear ratio and trans.......3.54:1 (Dana 60) and greater or 3.55:1 (8-3/4" Chrysler) and Hemis with automatic trans usually got 3.55:1 Chrysler......Hemi 4 speed cars used the Dana 60 rear. ........just my thoughts......so a 69 Hemi Roadrunner should have one ?
Last I looked, ten years ago, their radiators were $1400. I'm afraid to see what they charge today.Oh, piss off, Glen Ray.
FOUR hundred dollars? Really?
A GLENRAY reproduction max cooling 26" radiator # 2998956 (with shroud, 7 blade fan and torque drive clutch) for my GTX, RS23V0A******** was $1400 + shipping.....guaranteed for as long as you own the car...,,,and it performs exceptionally well holding coolant to 185°F in stop/go traffic with 100+ degree F ambient.......moral of the story....you get what you pay for......$1400 is a great price......or are you a person that squeezes nickels, then ******* when their selection doesn’t cut it........cheap is not the best bargain.......just my opinion......Last I looked, ten years ago, their radiators were $1400. I'm afraid to see what they charge today.
It would likely be a six (6) barrel engine, (or Hemi) 4 speed trans, 3.54:1 (or 4.10:1) Dana 60. My RS23V0A****** has the A34 Super track pack option and has the Dana 60 4.10:1 rear. Suggest you climb under the car a look for the red & white tag on the left side axle tube and ratio tag under a cover mounting bolt. Do you know the physical difference between Dana 60 and Chrysler rear? Or are you just speculating?? Btw....the Dana 60 is a Sure grip clutch type carrier........RJ so with a Dana 60 and 410 gears from factory it would have one
Date coded for the guys that are restoring high end cars. (like 6 pack and Hemi cars) So piss off.Oh, piss off, Glen Ray.
