Did you shorten them?And still happy with this conversion after many more miles (and years) =)
do you remember what brand you installed? I'm seeing some bad reports on the Moog ones for quality.And still happy with this conversion after many more miles (and years) =)
I did. I meant to respond here earlier today about it.I remember that article. I may plan to do this upgrade to my front sway bar when I up-size my torsion bars later this summer.
I think I recall seeing KernDog having a set of these, but can't recall if he ever installed.
No shortening required - Moog K750074do you remember what brand you installed? I'm seeing some bad reports on the Moog ones for quality.
yeah, my car is 1968 so I would be able to use without shortening. You've reported good longevity, which is awesome. I would also like to hear long term reports from others as well since I'm seeing some early wear issues reported in online reviews.No shortening required - Moog K750074
Long term?yeah, my car is 1968 so I would be able to use without shortening. You've reported good longevity, which is awesome. I would also like to hear long term reports from others as well since I'm seeing some early wear issues reported in online reviews.
Thanks. Sounds like I'm adding this to the short list of to-do itemsLong term?
I made the switch to these when I had the engine out in 2022. I changed the brakes in the car then and swapped in these links. I expected an increase in harshness but that never happened. They just work.
Just so I'm understanding correctly, I need to buy 2 identical, one for each side if my LCA's have sway bar tabs, correct? And if not then 2 identical 90-degree parts? Just confirming it's not 1 of each...No shortening required - Moog K750074
Are those extra you have on hand or did you dig up an old photo? You are a wealth of photos my friend!Since you already have a front sway bar, you just need two of these:
Those are extras. I bought two pair three years back. I took pictures of them with part numbers for instances like these.Are those extra you have on hand or did you dig up an old photo? You are a wealth of photos my friend!
