For your end on expenses the built 400 dressed as a 383 in the Coronet might net you more profit than spending good money to build a 440.
Depends on what you have in the heads for the 440 plus the few hundred bucks and time to build. Your decision, but unless those done heads are good closed chamber heads Your compression is going south. You have already spent the money on the 400. Only you know the bottom line on which engine has the least money involved. Good luck on your quest.OK that makes sense. The 400 is done and on a stand. The 67 440 would need built. But there's good news there as well. I already have the heads done on that engine. And while I haven't checked it yet, that engine supposedly came out of a wrecked car that was wrecked in 1973, and only has 27,000 miles on it. I haven't torn apart the block yet, but if I can just hone the cylinders and do rings and bearings on it, it might be worth building.
BTW I'm a mechanic with over 40 years of experience, so I have everything I need, and the skills to build it. If all it needs is a ring job, I could buy that kit for a couple hundred dollars.
And since I'm talking about it, it has flat top pistons in it, so what would the compression ratio be on a 67 440 with flat top pistons?
Well there's 2 problems with that. First - neither of the 400s are stroked. And one of them is fresh. The other one would cost me 2-3 grand to stroke and build. Second - as I just found out, the 440 6 pack engine is dated 7/21/70 which means it needs to go into the 70 Challenger. So, do you still think I should pull the tired 400 out of the Challenger and spend a ton of money stroking it, or just put in the running 440 6 pack engine?T2R9 covered it in post#9. Exactly what I would do!
Well , put the Sixpack 440 in the challenger, but make sure that you don't say it's a 440 Sixpack car, cause any buyer is sure to check.Well there's 2 problems with that. First - neither of the 400s are stroked. And one of them is fresh. The other one would cost me 2-3 grand to stroke and build. Second - as I just found out, the 440 6 pack engine is dated 7/21/70 which means it needs to go into the 70 Challenger. So, do you still think I should pull the tired 400 out of the Challenger and spend a ton of money stroking it, or just put in the running 440 6 pack engine?
Mine is actually an Edelbrock intake manifold with the correct carbs on it.And a 6 pack is an induction. Which could be installed on any 440.
So I guess that leaves the fresh 400 for the Coronet.
I didn't realize sales was the goal.
I think either would sell fine. I sold my 68 440 Coronet Superbee Clone with a 77 400 badged as 383. I sold it over a year ago for $43k. It was a high #3 car and definitely not original.So you think the 400 would sell better in the Coronet than the 440?
Totally lost. Of all the 440s, 67, 70, 72, how many are 6 packs??
The actual 67 C HP 4bbl block is a nice one.
Oh ok thanks. The one in post 27 looked like C . But if it's a G, it's a 71 block.Well, I actually have a 70, a 72, and a 77 440 engine. I thought it was a 67, but it's a 72 block with 67 heads on it. The 70 block is the 440 6 pack engine in the Coronet. It's the one that needs to go into the 70 Challenger.
