Kick down linkage on a 64 plymouth
Ceedawg
7:27 AM
Va
Looking for pictures of FACTORY set up for a big block also the cable part on manifold.
On the small block the kickdown is solid....meaning no slot. If big block is the same, you may want to do it a different way for safety.
A friend has a SM, the bracket on manifold has a u-shaped bracket using one rod down to lever on trans. Carb end has an adjustable slide type affair with spring holding it forward. Thanks to all seems I found my answer
