- 6:47 PM
- Dec 21, 2013
- nestor falls ontario
I’m putting back the original brakes on my 67 convertible, I got the parts from my brother’s 68 GTX the rotors and calipers. The callipers were rebuilt by John Stuart and I’m machined the rotors. When I got the rotors, there was a 1/8 shim underneath the inner bearing race. I removed the shim from the-race and put the bearings on the rotor and I couldn’t get the lash out. I put the shim in behind the inner bearing race and installed it and put the calliper on, and I couldn’t turn the rotor. I put the shim on the spindle, then bolted up the rotor and put the calliper on and everything is fine. I have the right inner and outer bearings. The only thing I can see wrong is the rotor. what would I do to resolve this problem? i’m not familiar with these parts. The distance between where the inner race goes to the outside of the hub is 1.250. there is no part number on the spindle, but there is on the inside of the rotor. As you can see in the picture.
