Charlie Brown
- 11:07 PM
- May 23, 2021
- Vars, Ontario, Canada
Just did a home alignment on my 64 Dodge. I'm using an older Snap On bulble unit with alignment plates. The following readings are what I obtained. Drivers side - neg 3/8 camber, positive 1 3/8 castor. Passnger side - neg 1/4 camber, positive 1 5/8 castor. Toe in set at 1/8 inch.
Car pulls slightly to the right.
Both tires showing more inside tread wear (18 k on tires)
Steering wheel is slightly off center.
All suspensions components good. Borgsen steering box.
Brakes adjusted properly and not draging.
I was of the impression that the car should pull to the opposite side (drivers) because the castor is less by 1/4 degree.
I'd like to get the car driving without any pull. Thoughts please.
