Home Alignment Results
Charlie Brown
12:33 PM
Vars, Ontario, Canada
Just did a home alignment on my 64 Dodge. I'm using an older Snap On bulble unit with alignment plates. The following readings are what I obtained. Drivers side - neg 3/8 camber, positive 1 3/8 castor. Passnger side - neg 1/4 camber, positive 1 5/8 castor. Toe in set at 1/8 inch.
Car pulls slightly to the right.
Both tires showing more inside tread wear (18 k on tires)
Steering wheel is slightly off center.
All suspensions components good. Borgsen steering box.
Brakes adjusted properly and not draging.
I was of the impression that the car should pull to the opposite side (drivers) because the castor is less by 1/4 degree.
I'd like to get the car driving without any pull. Thoughts please.
It will pull to the side with more positive caster.
Your left to right readings are very close to equal. I doubt that caster or camber is causing it. Tires can cause a pull. I assume they are radial. I would swap the front side to side and see what it does. If the rear are the same size and wheel you could swap them to the rear. For what its worth a slight pull to the right could be road crown related.
These cars have an easier time getting higher caster numbers the lower that the suspension sits.
I like to have some negative camber, at least 1/2 a degree at the bare minimum. Sometimes it looks like the caster number is great but then the camber comes in near zero. To get some negative camber, you have to give up some caster. THIS is with all stock parts.
Unless.....You start off with this:
Use a washer between the lower ball joint and the knuckle/spindle. This tilts the bottom out while adding negative camber.
Now, you already have a bit of negative camber to work with.
Your caster values would if switched would eliminate the drift on normal road crowns. Drivers side should be more positive than passenger side.
Also your negative camber values over time can contribute to inside tire wear.
Tire wear with negative camber?
Yeah, with bias ply tires. Radials can tolerate some negative camber because the sidewalls flex a bit, allowing the tread to maintain a better contact patch. Who still runs bias ply tires except for the dudes with stock restorations?
You'll chew up tires much faster if your toe settings are out of whack no matter the type of tires you're running. Why? Well with the tires aimed wrong, they are scrubbing the pavement as the left tire fights against the right.
R413 is correct on which side it will pull towards based on caster bias. Be sure all your tires have equal pressure.
I'm not sure where you got this info. It will pull towards the side with the lower caster. Higher camber can cause it to pull as well, but to a lesser degree. The specs given here are good. They shouldn't cause any pull. If the road is flat it should go nearly straight. The first place I'd look is the tires. Radial tire (I'm assuming radials) pull is common.Swap the tires left to right. The wheel could be off as a result of having to hold it to go straight. Or It just needs a tweek of one sleeve rotated in and one out. Pretty common even using a decent alignment rack. Get the pull figured out first. If the tire swap doesnt fix it, sometimes the caster/camber need a little tweek as well. Move the left rear cam outward to add slight + LF camber and reduce LF caster. If you tell me how far the wheel is off and which direction it's off that''ll give the info needed to make a tie rod sleeve move. Probably done over 5000 alignments during my career.
Here's some guidelines that don't cause pull or tire wear.
2 things you can try to check if the pull is road crown related.
On a 2 lane (as long as it is safe) swap lanes as the road slopes from center to the left and right in most cases for rain run off.
The other is a flat parking lot that maybe is 45 meters or so to see if it tracks straight.
^^^^^ Someone in this thread who actually knows what they're talking about.
Thanks for this. I do have radials. I'll switch the tires side to side and see what happens. Do I need to swap the rear tires side to side as well? In regards to the steering wheel center, it needs to rotate counter clock wise to be centered.
I stand corrected, I was in error about caster
Here's a good way to remember it
Pulls to least  ca ster
Or  most ca mber.
Or  most ca mber.
Yep.
MY method remember it is
IN on the FRONT upper control arm mount / pivot is NEGATIVE caster
IN on the REAR upper control arm mount / pivot is POSITIVE caster
My own personal car, I have the rear cam adjusted where its all the way in, Then adjust camber / caster pull with the front . Then set toe in
This was all done sitting on my garage floor. with no alignment gauges of any kind. SO,,,,,
I have no idea what I have for 'actual' caster measurement in degrees. But mine doesn't eat tires Or pull to either side on flat roads
You alway move both wheels in the direction the wheel is off. In your case the wheel is off to the right. So think of it like this. The wheel needs to be rotated counter clockwise to be straight. With the car setting still do just that. Now you will see with the wheel straight the tires are pointed to the left. Thus with the wheel now being straight both tires have to go to the right. Toe the left wheel inward, and the right wheel outward. Move the sleeves exactly the same amount. You didn't say how far off it is. Start with a 1/2 turn for each side. It may need more, may need less. Just be very carefull to turn both the sleeves the the same direction of rotation and the same amount.Then test drive. When you have the wheel straight recheck your toe. If it's off adjust both sides equally. This is a sensitive adjustment. One complete revolution is only .0555". I have seldom seen the rear tires cause the pull. But it is possible. Cross the fronts alone first.
