Headlight connector access
Moparfiend
9:09 PM
HOT
Anybody got some tricks up their sleeves to help me figure out how to get access to the connectors at the back of my outside headlights without removing the front grill?
My front grill is really fragile and I don’t wanna take it off if I don’t absolutely have to. What I’m trying to do is rewire the harness for the headlights using an additional relay harness. I need to unplug the connectors and plug the new ones in.
I can’t quite gain access to the outer headlights in the quad headlight set up. I can see them, but I just can’t get my arm in there.
Any suggestions or tricks anyone’s found to unplug the headlight connector on the outer headlight without taking anything apart?
Can't you remove the lamp bezels and bulbs without touching the grill?
No way to do it, must remove the plastic headlight bezels. Don't need to remove the grille.
No there is no access to the ring screws without removing the bezels.
