Blue Brick
A 1-1/8" socket with a 3" extension.I mentioned that already in an above post.
Thank you. Just to be certain, the correct direction to turn the pulley is counterclockwise or clockwise?
I do appreciate the assistance.
UNDERNEATH, there is tons of room. If your gonna lay on the ground to turn a torque converter wrench, you can lay on the ground to properly turn the crank bolt.I’m sure you're familiar with motors, but I wanted to share a photo of mine for context.
Except it’s a 1 1/4 socket not a 1 1/8. KimI mentioned that already in an above post.
Oops, typo.Except it’s a 1 1/4 socket not a 1 1/8. Kim
Remove the #1 spark plug, cover hole with finger and turn the crank with the ratchet. When you feel compression, keep turning clockwise until the next balancer mark lines up with the timing mark on the timing cover and you are now at TDC on the firing stroke.I'm currently under the vehicle. The crankshaft dampener has several timing marks on it—how can I identify which one is the top dead center (TDC) mark?
We had trouble confirming compression at the cylinder, so we used the pencil method to find TDC. The pencil did move, indicating piston travel. While under the car, I noticed two timing marks already visible on the dampener, and a third one is approaching the timing tab
