Yesterday, I had my buddy Dave vacuate the system, replaced the $19.00 trinary switch, recharged the system & it works like it's supposed to. 50 degrees of cold air coming out the vents.
Those wires will look neater with a twist.Yesterday, I had my buddy Dave vacuate the system, replaced the $19.00 trinary switch, recharged the system & it works like it's supposed to. 50 degrees of cold air coming out the vents.
No way.. it needs a lot of thisThose wires will look neater with a twist.
And this... Make that thing snazzy!
This one needs the snazzy stuff, bad!
Not what I had in mind but looks good.
Have enough problems with what I have.Are you offering?
What radiator are you using?I did use some of that stuff, but I kept it at a minimum and tried to hide it as much as I could. It's mostly on the RH inner fender and is mostly hidden by the computer, relay box and heater hoses.
