#41
Got it! Makes sense. Sounds like I might need to replace these sooner than later. I get the valve stem under the bumper is to take air in/out but any idea what the nipple is near the license plate is used for? I was thinking it looks like if I was to loosen it air comes out?
As I mentioned before, air shocks can be set up in different ways. You just have to put air in and out and see what happens. While air shocks typically last a long time, they can wear out or blow air lines.... so if they are older you may be due for new shocks. You'll find out soon enough as you experiment putting air in and out.
