Drivers side remote mirror, different mounts on B Body?
Daytona Jim
11:54 PM
Napa California
I am seeing two different mounting styles on 67-70 B Body. One style is, looking front to back, mounting stud then control cables then sheet metal mounting screw. The other style is control cable then mounting stud then sheet metal mounting screw. Has anyone seen the difference I am describing in the outside remote mirror mounting? Thanks Jim
@Daytona Jim
The original driver's door and manual mirror on my 1970 Charger.
Mirror base:
2802699
53093
JC-60271-402-1
Mirror dish/housing:
2802148
53093
JC-60271-401-1
Note the two sides of the gasket are not the same.
I'll post an update as soon as I find the OEM remote control mirror I bought in the late 1980's.
@Daytona Jim
Pictured below is the driver's remote and it supposedly came off of another 1970 Charger. I do not know if that is true.
Obviously, this remote mirror mounting is totally different than the non-remote on my 1970 Charger.
3796634
53093
The first digit in the bottom numbering is difficult to read.
30549-401 First digit is a "3"?
50549-401 First digit is a "5"?
60549-401 First digit is a "6"?
Close-up:
Bonus picture:
:p
The screw pictured above secures the round mirror housing to the pedestal base.
@Daytona Jim
Side-by-side comparison of the two mirror bases.
Also, the round housing for the remote mirror is noticeably larger in diameter.
4-7/8" outside diameter of remote housing.
4-1/2" outside diameter of manual housing.
First thing. I want to thank you Delta V for all the effort and information you gave in your response to my remote mirror question. My 69 Charger was a "rescue" when I found it. The car had been picked over pretty good when I bought it. The car did not have a driver's door mirror on it, but the mounting wholes on the driver's door match the picture you sent of your 70 Charger door. My next question is are the mounting holes in the door the same for a remote mirror and a standard mirror? I would not expect Dodge to stamp two different mounting hole arrangements. Thanks again Jim
@Daytona Jim
View attachment 1891197View attachment 1891198
3796634
53093
Close-up:
Bonus picture:
:p
That is a later B-body 75-76 Mirror.. Fits a Charger but a 75-76 Model..
Agree. See more below.
The remote mirror in this old for sale ad appears to have the same mounting arrangement as my standard mirror.
How about this...is it accurate/correct?
Those are correct..
I "think" we can safely say the holes in the door are the same for the standard round and remote round mirrors for 1970 Chargers.
Also, the "sport" mirrors appear to use the same hole patterns as per below:
PRIMED SPORT
Sku: TRIM-MRR070ABL-PNT for left remote
Sku: TRIM-MRR070ABR-PNT for right manual
or both left and right
Sku: TRIM-MRR070AB-PNT-SET
Mirror Set - LH remote - RH manual. Primed Sport Mirrors for 70-76 A Body and 70 B Body. Replacement for 3586655 and 3586176.
Note: The gaskets look like the one on my standard driver mirror.
Reference:
70-76 Mirror Set - LH remote and RH manual Primed Sport Mirrors for 70-76 A Body and 70 B Body
CHROME SPORT
Sku: TRIM-MRR070ABL for left remote
Sku: TRIM-MRR070ABR for right manual
Sku: TRIM-MRR070AB-SET
Mirror Set - LH remote - RH manual. Chrome Sport Mirrors for 70-76 A Body and 70 B Body. Replacement for 3586174 and 3586175.
Reference:
70-76 Mirror Set - LH remote and RH manual Chrome Sport Mirrors for 70-76 A Body and 70 B Body
__________________________________________________
Other info:
G: GLASS - MIRRORS
Mirror O/S Rt. 3_:
This box was used to identify if the car was ordered with an optional right hand passenger side mirror (option code G31). This option would be reflected by a value of "1" in the box. If the box is empty, the car did not come with a right side mirror.
Remote Mir. Or Del. 3_: This box was used to identify the type of left hand drivers side mirror, and in cases where the G31 right hand mirror was selected (see above), identify the matching style of the right hand mirror. The applicable codes here would be:
3 = Standard Left Hand Remote Chrome Mirror (Option Code G33)
5 = Delete Standard Left Hand Chrome Mirror (Option Code G35)
6 = Left Hand Remote Chrome Mirror with Right Hand Manual Chrome Mirror (Option Code G36)
6 = Left Hand Remote Painted Mirror with Right Hand Manual Painted Mirror (Option Code G36) - Available February 1970 only in colors EB5, EF8, FJ5, EK2, EV2, FK5, FY1, FY4 and FC7. Mirrors would be chrome on all other paint colors.
Reference:
1970 Dodge Charger Registry
Have 1 first Gen, factory. The mirrors are not in the same location.
When I added the passenger mirror to this car I put the mirror on the door with dum dum. Then sat in the driver’s seat and tested the view. Moved it until I could use it. Made sure it didn’t interfere with the vent window. Marked it drilled my holes fastened it.
Doesn’t matter to me how it works for someone else.
Hi All, great thread. I especially didn't realize 'Sport' Mirrors were available on a 70 B-body? I'm seriously considering these for mine. Does anyone have any guidance on how to add the remote left mirror parts on the inside of the door panel? Is it just a hole through the door fiber board? Thx
@Daytona Jim
3796634
53093
Close-up:
Bonus picture:
:p
That is a 75 and up mirror.
Factory 66 and 67 mirrors are in the same location on both sides.
...and I have proof.
that's how I have done it.....
IDK.
It looks nice.
That's the "non-sport" mirror.
They changed the mounting pretty radically for 75, with stamped, "hemispherical" indentations in the door skins.
I tried to make a pair of 75 and up sport mirrors work on a 74 by drilling holes....
...FAIL.
I still have the really nice, painted mirrors with pass side remote...
...and plan to see if I can cut/grind off the protruding hemispherical sections, or take them apart and see if the mirror housing will mate with a 71-74 "stalk" section.
The hole for the remote mirror doesn't go through the door panel. It attaches to the trim pad that covers the upper door frame. There should already be a hole stamped in your upper door frame.
Hole location in upper door frame:
Location on upper door panel trim pad is below. I believe the hole for re.ote can be punched out. Check yours to see.
