Stove Pipe Aftermarket Header Clamp On Fitting
RR Fan Dan
If it ain’t broke, fix it till it is.
12:58 PM
Virginia Chesapeake Bay
Is there such a thing that clamps to aftermarket headers to attach your stock air cleaner hose pipe to?
That would be very easy to fabricate. Use a stub of 2"exhaust tubing and cut two opposing "legs" which you then bend at 90* out and hose clamp to the closest header tube. Leave a 1/4" air gap when you make your bends to allow air flowing over the header tube to gain heat.
