B Bodies & 340’s
Moparfiend
5:35 AM
HOT
I would like to know some specifics regarding the automatic drivetrain combinations used in say Roadrunners with 340’s.
What rear end and torque converters (stall specs) were used along with engine compression ratios and camshafts specs if possible.
Thanks MF
First year for a road runner with a 340 was 1971. Because the
340 is down on torque with 340 ft lbs compared to a 383 with 425 ft lbs of torque.
And 340 is down on horsepower with 275 compared to a road runner 383 at 335 horsepower. A 1966-1970 b-body is a heavy car, that's why the factory didn't put a 340 in them.
340 was an A body only engine in 1968-69, and really make a good combination.
1971 road runners were smaller and lighter cars by about 300 lbs depending where you get the numbers. Better aerodynamics also.
If I’m not mistaken, the 1970 was rated approximately 200lbs lighter than the 1971. But 3/10 sec. in a quarter mile isn’t a big deal either, but let’s not go there because this is not what I was asking for.
I am however, asking about the set ups. Anybody out there with a 71 to 73 roadrunner with a 340 in it that wants to comment about their configuration?
I’ve got a 69 Charger with a 340/727. The casting date is late 69 on the block. I bought it like this. The only thing I know about it is it has a crane rocker set-up and some lumpy cam, an edelbrock manifold and carb, HEI distributor and headers. It’s faster than I thought it was going to be.
It had 3:55’s that I swapped for 3.23’s for a little more highway.
Don’t know if that helps, but I like it.
Searching on the hamtramck registry website (dealership data books) you’ll find several specs about axle ratios, compression and basic stuff like that… but no mention to more technical stuff such as TC stall or specific camshaft specs… just says “hi-lift”.
And the “compression ratios” is just a number based on engines IF were cut “blue printed”… which was not! LOL
TC tables and the procedure for stall testing are in the factory service manuals. Similarly, compression ratios, valve sizes, valve timing, and etc. are identified.
Factory Service Manuals and other data are available for download to your computer for FREE.
The mymopar website is nice:
Service Manuals – MyMopar
Happy reading!
My 73 Road Runner was equipped with a 340, 727 and 8 3/4 rear. I believe that all 340s got 727 transmissions, and likely 8 3/4 rears too. But I am not 100% certain about that and I'm sure someone will correct me if I am wrong.
My particular car had a 3.55 sure grip, but 3.23 open rear was standard. I don't know the stall spec of the torque converter though.
Thanks I didn’t know they put those in chargers back then
What was the performance like just out of curiosity?
I disagree about 66/67 being heavy cars.
A 2 door "23" body 66/67 is light as hell.
Almost as light as an A body.
...but the 340 was introduced in 68.
71-73 RR and Charger 340 cars could have 3 or 4 speed manual trans not all 727.
71 through 73 came with 8 3/4 axle.
Sometime in the 73-74 production changeover, the 9 1/4 axle was introduced.
In 1973 the 340 had reduced compression (don't remember the ratio but you can look it up), and a shot peened cast crank with external balancing. The heads also had smaller valves. IIRC, the horsepower was rated at 240.
I was 16 when I started driving it, and over time I added headers and a better exhaust. It actually ran OK, but a few years after I got it the oil pressure was low enough that I rebuilt it to 69 specs with a hotter cam. I upgraded the heads to 2.02 intakes, like the 69 spec. After that, it really ran strong but needed really good octane to run well. After a time I tired of having to put octane boosters in it, so I reduced the compression to 9.33:1, using a special cut that improved quench area that my father-in-law sort of developed at the time (now it is common). I swear after reducing the compression the damn thing ran stronger than it did before.
Bottom line is I have a GREAT respect for 340s. They are an engine that Chrysler just got right. Build them right and they will run like a scared ape!
340 compression ratios as per model year FSM:
10.5:1 for 1968
10.5:1 for 1969
10.5:1 for 1970
10.5:1 for 1971
10.2:1 for 1971 cited by internet sources.
8.5:1 for 1972
8.5:1 for 1973
Interesting seeing this same drop as Chevy did the same thing dropping compression to 8.5:1 in 1971. It was an industry wide thing apparently for new epa laws.They purposely detuned them by lowering the compression then loweing the factory advance to like 8-12°. I had a 1971 Corvette with a LS5 454. They had bruched aluminum ID plate on the console my the emergency brake that had some specifications one of which was compresion ratio. The 454 that year dropped to 8.5:1 and that year that motor the way they tuned it from the factory was like a truck engine.
I have a 73 roadrunner, the original 340 sits in the corner of the garage. The 340 in the car was punched out 40 thousands, at 11 to 1.I switched to a steel crank from cast shot peened, internal balanced now, I'm running EX 274 comp cam, with 3200 stall torque converter and 4:30 gears in rear end. It gives any big block car a run for its money out of the hole.
This the first car I bought back in 1981 and still have to this very day. It's just a toy filled with memories now.
Should run good with those modifications.
Now do all the same mods and upgrades to a 440 and line them up. With slicks ar the track so we have a time slip. Now who wins?
I don’t think anybody’s going to challenge or imply that the 340 versus the 440 identically set up would generate more horsepower or torque.
