67 Coronet 440 Auto
Brew61
8:45 PM
Penticton BC
OK so over my years I have built engines but have always been Chevy engines. This is my first Dodge build. Well its not really a full build as the engine has already been rebuilt and has very little milage on it but its basically stock 79 440. I just plan on intake cam and headers. So I purchase a Edelbrock Performer RPM Intake Manifold 7193. Might be going with a TTi shorty header. Just trying to figure out a cam.
Now I am not sure how the 440 reacts to certain cams , but just looking for a street cam, little lumpy idle, good for in town and hwyway driving. Running a 727, gears might be 342 I will see but not much lower than those.
first cam
https://www.summitracing.com/parts/sum-k6421
Second came is old stock but brand new Crower
Engine Application: 440 MOPAR
Grind Number: M280H / MONARCH
ADVERTISED CAMSHAFT SPECIFICATIONS:
INTAKE:
Duration: 280°
Lift: .465
EXHAUST: Duration: 280° Lift: .465
Clearance Hot: .000
Clearance Hot: .000
The specifications listed above are bassd on a rocker arm ratio of 150 IN
The information below is for degreeing cam
only. Correct only at .050" tappet lift.
INTAKE
Opens: 6.0 BTDC
Closes: 38.0 ABDC
EXHAUST
Opens: 46.0 BBDC
Closes: -2.0 BTDC
LOBE SEPARATION 110°
Duration at
.050"
LOBE LIFT
Intake: 224
Exhaust: 224
Intake: 310
Exhaust: 310
Would either one of these be suitable
thanks
Bruce
The first one is about the tiniest cam I've ever seen.. no.
Second one is not bad but has a pretty big seat duration for the .050 duration.
The post had a reference to a member who sells old school lifters, you could also give Crower themselves a call and see what they recommend. Unlike lot of the others, they are still owned by the same company that founded them 70yrs ago, so they might have a set floating around.
The second cam is pretty close to the 383 RoadRunner/SuperBee and 440 Magnum piece. It gives a nice lopey idle and lots of vacuum for power brakes. A good street cam.
First cam could use a narrower LSA for the low compression ratio of 79 440. And the second cam has a little to much duration but a better LSA. I think Comp K21-221-4 might be just right.
Well the Crower cam got sold so that one is out of the question now. Didn't think it would sell in one day but oh well. So now will have to decide on something else.
Bruce
The Monarch specs are very close to the Comp Cams 270 Magnum cam, a good choice for your needs.
Well it looks like I will just go with a comp 270H. I have ran lots of comp cams over rite years in Chevy engines and have never had any issues so I guess I will try another one in this 440.
Bruce
