Torsion bar question
Allan Y
New Member
3:12 AM
Winnipeg, Canada
How far can torsion bars be adjusted up?
Recently bought a 1967 Plymouth Satellite. Problem is the front end sits incredibly low. I would like to crank up the torsion bars but I read of conflicting suggestions of how high is too high.
Any thoughts?
It's pretty uncomplicated.. tighten them up till it sits right. ( flat, even)
The bars might be sacked right out too.
Unless the bars are completely wasted, you should certainly be able to crank em up to stock height, and maybe a little more.
Probably can't achieve gasser straight front axle height.
Jack up the front, take the weight off the suspension before you crank em. And some penetrating oil couldn't hurt.
Make sure your shock absorbers are in good condition. Worn out shocks make springs work overtime & the springs will sag.
If it's too low: :thumbsup: It rode like a truck but looked cool back in 78. Oh, I didn't re-align the front end either.
Any thoughts?
All the way up, but that will effectively be almost a locked suspension, and alignment will be so far out of range even an alignment shop would not be able to correctly set it. So, your question is rather impractical, but answered.:popcorn2:
Ride height at whatever height it is, effects your alignment.
Allan, looks like you're new to the clan. Welcome! How about a picture of your Satty?
There IS a limit ... the adjusting bolts can only go so far into the blocks until they bottom out. If the bars are too soft then you'll not be able to achieve a proper ride height.
Here are procedure and specs from the Factory Service Manual (FSM) which is available in PDF from mymopar.com
EDIT: replaced pictures with better screenshots off the computer rather than my phone
