Ballast Resistor for wiper motor?
Moparfiend
10:06 AM
HOT
I am getting only high speed and no park on my wiper motor. I don’t see an external resistor and understand this controls the wiper speed and park. I am enclosing a picture of my wiper motor as it looks different from other wiper motors that had resistors externally mounted. This I believe is the factory original motor. Can anyone tell me if I need an external resistor and how it would be hooked up?
Thanks for your assistance on this MF
The resistor used on Chrysler two speed car wiper motors from 1968 through ~1976 on passenger cars and into the 1990s for some applications including minivans, is the wiper motor torque limiting resistor, part number 2822261, and ranges 0.25-0.5 ohms in resistance. It is an open back, ceramic power resistor. The resistor limits current and results in a lower applied voltage to the motor for low speed operation. Although it is a power resistor, and looks similar to one, it is not the same as an ignition ballast resistor.
The resistor mounts with a metal strap to the hole at the upper edge of the motor. The same screw secures the ground strap to the body of the wiper motor and between the mounting nut and the rubber bushing ferrule as shown in the following image. The two loose wires seen in your picture connect to the resistor terminals as shown in the following image.
You need the ground strap and a ballast resistor. BTW ... not a very good pic !!
Sorry it is what I had in my library. Here is a better picture I hope.
Awesome thank you very much!
Question without the ballast resistor, I understand that the lower speed will not work at all, which is the case for me. However, will not having the ballast resistor also cause it not to park? When shut off the arms are in all different positions.
If the arms are each in different positions you need to take one or both off the pivot(s) and clock it to the correct or desired position. They can be a bitch to get off. There is a small clip under the base that has to be held back then the wiper pulled off. Good luck!
You could also jump those two loose wires together. The motor will only run fast on either speed but it will work. The "park" is controlled inside the base of the unit and isn't accessible.
Troubleshooting no park, or stopping in any position, from the factory service manual:
Testing procedures are also in the factory service manual.
Thanks guys. I am sure to develop at least one more question when I get in there.
Just out of curiosity, does your Sport Satellite have buckets and console?
Correction the ballast resistor is part of the parking circuit! With this new ballast resistor the wipers now park correctly and low speed is attained! This contradicts what many think but I have proved it by turning this circuit on and off. The wiper internal circuitry is a black box so I can’t explain what’s going on inside, but I can confirm positively that the return signal uses this resistor.
Getting the correct resistor 0.5 ohms in the right configuration as the original is not simple, but it is achievable. Not sure how long though because I’m not sure they’re still being manufactured like this.
Well it only makes sense that the park would use the resistor ... the park works slowly, it doesn't slam down at full speed !!
Be advised the wiper motor resistor is not just a plain fixed value power resistor..
It uses nichrome wire internally that increases resistance as it heats up
as to protect the wiper motor from overcurrent.
Just my $0.02... :thumbsup:
