- 12:30 AM
- Jul 1, 2015
Not totally correct. There's no zener diode connected to the.5th pin but a complex voltage divider network. On the later 4 pin ECU, the circuit was redesigned using a resistor/capacitor/transistor network including a programmable SCR to furnish the dwell function as well as shaping the keying pulse to the external switching transistor on the outside of the ECU (which actually controls the coil's primary current) to cause the spark. Perhaps, you can show the two different ECU SCHEMATICS as an example of what you are saying......On the stock ECU, the 5-pin module used the dual ballast resistor with the 5-Ohm section feeding into the fifth pin which connected to a Zener diode inside the box to create a voltage regulator for the ECU. The latter 4-pin ECUs just put the 5-Ohm power resistor inside the ECU. I don't know about the Rev-N-ator if it uses the fifth pin?
https://www.electronics-tutorials.ws/diode/diode_7.html
BOB RENTON
