What ATF in 2025?
440 PHIXX
The Island of Misfit Mopars
9:35 PM
Hatfield Pa.
I looked at Walmart and Autozone, and nothing says Dexron anymore. I was using Dexron III but all the stuff says Mercon. Is that basically the new name for stuff that will work in a 727? Funny thing… I still see Type F.
ATF+4 I think is a good option. But I would wait for better answers or read up on this. I believe Dexron/Mercon is a sort of Universal transmission fluid. Dexron is GM branded Mercon is Ford branded and ATF+4 is Chrysler branded. Type F is another Ford transmission fluid type I think for older cars.
All Types Of Automatic Transmission Fluid Explained
ATF+4 if a fresh build. Dexron/Mercon if you’re topping it off or flushing it. Napa carries it.
I remember Type F as Ford back in the 70’s when I was a kid. Some of the guys that ran Mopar TF’s at Atco ran the Type F and said it offered firmer shifts.
Type F doesn't have any friction modifiers in it. Because of that it will offer a firmer shift than Dex/Merc (or any other ATF for that matter). Type F isn't suitable for anything with an overdrive, one could use it in an TF but Dex/Merc or ATF+4 are better choices.
The thing about Dex/Merc is that there's not any OEM that uses it anymore so there isn't any OEM oversight to the formulation anymore. That said I still run it and it's fine in older stuff. The oil companies have been making it for decades so I doubt they have any motivation to skimp on the formula. I still run Dex/Merc in my '94 Ram 1500 with the 46RH although I leave the OD unplugged in that one.
For any fresh build it doesn't make sense NOT to use ATF+4, it certainly won't hurt any TF either...
Look up the chemical specs for ATF+4 and you will have no doubts about using it.
I have 3 mid 90's trucks with two being on it for a lot of years and one has been on it for about 5 years. They weren't fresh builds either.....
ATF+4
Good quality and affordable at wal-mart.
ATF+4
With the Walmarts around here, you have to go to more than one store if doing a fluid change....or order it. I got to where I'd buy it if I thought that a fluid change would be happening within a year lol. Some WM's didn't stock more than 6 quarts.
If it's like mine for the Mopar Oil filters just climb up and there on plenty stacked on the top of the shelf!!! Had to do that many times..
I've been running type F in my race torqueflites for a long time with no issues. Can't speak to the high-mileage longevity of it though. The last time I changed the ATF in my road-going mopars they got Type F but it's only been a few thousand miles. It seems to play nice with high mileage '81 model lockup 727 converters, it locks up better than the old fluid which was genuine Dex II
