Front suspension squacking ?
Cornpatch MO
3:15 PM
Southwest Iowa
I had a constant noise in the left front suspension of my 1968 Sport Satellite . I could not find where it was coming from . Rubber bushings are fairly new . . I finally found it ... the shock absorber rod making the seal squeel .
Sorry to say, that was not the problem . I drilled a small hole in the outer tube and siliconed the P out of it ... Still squeeks .
It can be any of the front bushings on that side. Did you rebuild with poly or rubber ?
Noises , lol, Steve I chased a buzzing sound for awhile, Ended up one of my Flowmasters had a baffle that came loose.
That stuff will drive you nuts.
Maybe the shock mounting rubbers are shot, causing the squeak.....or the shaft seal is dry.
Could be , my eye sight is low, and those lower shock bushings are a B. to get to . shocks are not old .....Thanks
When I bought the car , the seller told me he had rebuilt the front suspension . . they look pretty good ... they are rubber . BTW there is a car show up your way about the middle of Sept. Another friend of ours is putting it on . I think we are going to try to make it . .... Thanks
