What spark plugs are you using in your 915 heads?
The problem with statements like...more hp with later type spark plugs tends to refer/concentrate on peak hp, eg it made 10 hp more at 5800 rpm.
No mention of the smoother idle that occurred when a different spark plug was tried. The smoother idle is a result of more hp at idle rpms because there are less misfires, a rough idle being caused by misfires.
And changing to 'later' spark plugs can certainly add more HP as referenced in post #16 if the ign system itself is marginal. Such as a points ign system. Going to 'later' Platinum or Iridium plugs that require less arc over voltage could certainly improve ign with a marginal ign system, in two ways: less misfires & bigger plug gaps. Think about why dual point dists were used; it wasn't because the factory over-ordered on the pints & had to get rid of them......
Resistor plugs are strictly for ignition noise on the radio. They were also mandated by the government to prevent noise due to RADIO FREQUENCY interference???? The 2 plugs noted are available on line and work well in my RS23V0A, an origional 6 barrel car with a Prestolite Dual point distributor system. The plugs are NON PROJECED CENTER ELECTRODE CONFIGURATION......
BOB RENTON
To add to Bobs comments.. :rolleyes:
Early RF radio transmitters were of a spark gap design..
And during the 50s the US government strongly recommended to the major auto brands to go to graphite-based ignition spark-plug wires as to decrease RF interference for AM band radios. I recall back then the AM radio tuning dials actually had little triangle ICONs for CD (Civil Defense) @ 640KZ and 1240KZ. Note that Tesla cars have NO AM band, due to the RF interference coming from their high-powered inverters, RF interference is very common for the later car and entertainment products that utilize digital switching amplifiers and power supplies. AM radios have no noise limiters, but the majority of the later digital switching amplifiers and power supplies operate in the AM band. Even some higher-end car audio components actually change the digital switching frequency of their amplifiers and power supplies to outside the AM band when the user is operating the AM radio.
Just my $0.02... :thumbsup:
And changing to 'later' spark plugs can certainly add more HP as referenced in post #16 if the ign system itself is marginal. Such as a points ign system. Going to 'later' Platinum or Iridium plugs that require less arc over voltage could certainly improve ign with a marginal ign system, in two ways: less misfires & bigger plug gaps. Think about why dual point dists were used; it wasn't because the factory over-ordered on the pints & had to get rid of them......5
What a stupid thing to say....."Think about why dual point dists were used; it wasn't because the factory over-ordered on the pints & had to get rid of them......".<
Undocumented hearsay....or....typical sales information presented as an inducement for the uneducated or gullible person to purchase the more expensive plug (regardless of brand) to playcate the individual's desire to claim horsepower increase, smoother idle, better starting, better MPG, etc., and to demonstratue to his/hers cruise buddies how much better the engine runs, using the time-honored "seat of the pants" engineering principles.......
BOB RENTON
Your an idiot Bob.
Dual points were used because at that time in the planet's evolution, that was the best that technology at that time could use to improve spark output & engine performance.
Learn something.
Below is from the latest edition [ July 2025 ] of Race Engine Technology magazine. Even though the ICE engine is winding down, engineers & scientists are still working on ways to improve power & efficiency from petrol engines. In the example below, a separate small combustion chamber is used to ignite the air/fuel in the main chamber. Not a new idea, but a new approach
Below
Your an idiot Bob.
Learn something.
Let's have a thinking contest......90% of what you exemplify is incorrect. Once again no documentation to support your presence. It's the variation of the old Honda CVCC cylinder head/engine design......now obsolute with digital engine management. 99% of the motoring public is un aware or cares about the Race Engine Technology why quote it's attributes? Stick to changing parts in your garage......or share your engineering credentials not just excerpted un documentation from unknown sources........btw....your comments about dual points in distributors is still stupid........
BOB RENTON
NGK XR5s, I've had the same set in the car for 5 years, they do the job, I might replace them while I have things apart but they have been running fine.
BOB RENTON
Wrong! They primarily suppress radio frequency interference, but they also help protect sensitive electronic components from EMI interference.
A lot depends on which suppression system is used....some plugs use strictly resistor types, some use inductive suppression systems some use a combination. As to which is more effective....????.....it depends on what you're trying to protect.....although some plugs don't use any suppression systems and the world has not yet ended......some proponents say it smooths the spark energy for longer life.....????....
BOB RENTON
The majority of the posts for this thread has been about talking about different brands and various models...
But to me the most crucial task is to remove the spark plugs and reading them to analyze about their condition.
Reading the spark plugs can provide incredible insights about an engine's health and operating conditions. By examining the
color/condition of the spark plug's electrode/insulator, one can diagnose potential issues like carburator(rich or lean) fuel mixtures, oil problems,
and/or pre-ignition issues.
And the fools still don't get it:
[1] Dual points were used DURING THAT TIME PERIOD OF OUR EVOLUTION BECAUSE THAT WAS ALL THAT MANKIND HAD DEVELOPED SO FAR to extend engine rpm. With more knowledge came better technology, which led to higher powered ign systems & higher engine rpms.
[2] Spark plugs do not increase hp? Really? Look at post #15. The fact is plugs can & do increase hp. By reducing the reqd firing voltage, less misfires occur. Less misfires means the engine is making more hp.
If:
1.
The ignition system is working well, not marginal
2. There are no misfires
Does changing spark plugs still increase horsepower?
Again, an unrelated comment dealing with evolution and the economic evolution......without any substantion, other than speculation.....and some tired magazine article or U-tube like Dead Dodge Garage......sad......
BOB RENTON
Calling people fools ? Spark plugs DO NOT increase horsepower. I don't need post #15, I have my education. And I won't waste my time trying to educate you. But, I'll give you a tidbit :Technically, spark plugs do not increase horsepower; they only bring the engine back to its optimal operating horsepower. New spark plugs will make a car run as if it’s new. It doesn’t add to the predefined engine horsepower. I challenge you to provide a credible, knowledgeable source that maintains a spark plug "adds" horsepower. I'm shaking my head at your last comment.
THANK YOU FOR YOUR COMMENTS......not exactly sure WHERE this guy gets his allegedly expertise from......maybe it's wishful thinking.....????....small, randomly selected excerpts, without substantially accurately comments is useless........just my opinion and thoughts......
BOB RENTON
