Geoff 2
The problem with statements like...more hp with later type spark plugs tends to refer/concentrate on peak hp, eg it made 10 hp more at 5800 rpm.
No mention of the smoother idle that occurred when a different spark plug was tried. The smoother idle is a result of more hp at idle rpms because there are less misfires, a rough idle being caused by misfires.
And changing to 'later' spark plugs can certainly add more HP as referenced in post #16 if the ign system itself is marginal. Such as a points ign system. Going to 'later' Platinum or Iridium plugs that require less arc over voltage could certainly improve ign with a marginal ign system, in two ways: less misfires & bigger plug gaps. Think about why dual point dists were used; it wasn't because the factory over-ordered on the pints & had to get rid of them......
