Dibbons
- 12:42 AM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
After installing the timing cover, water pump, and harmonic balancer on this rebuild 340 project, the engine now rotates with extreme difficulty over 90 degrees of rotation. At first, i squirted VD-40 in the spark plug holes believing maybe one cylinder was a little dry, put that attempt provided no benefit/improvement.
Then I noticed that during a portion of rotation, the bottom of the water pump has no clearance with the harmonic balancer (photo #1). I don't know yet if the problem is with the pump, the balancer, or both. This problem really took me by surprise.
The smallest feeler gauge I have is .004" which I can fit it during partial rotation. Then at a different point it won't go in the space between the water pump and balancer. Then I placed some blue masking tape all around the balancer and found during rotation the tape starting to fold up on itself (photo #3). I have no idea what the normal clearance in this area should be. I do have another spare (old) harmonic balancer on hand (photo #2). The water pump and timing cover are new.
If I install an new balancer and still have the problem, I will really be perplexed. Standing by for input from my Mopar brothers. (also posted on FABO) Thank you.
