906 heads on a 413
413Polara
8:11 PM
Kingston Ontario
Have a line on a set of 906 heads for my 413. Wondering if anyone here has had a set on a 413 themselves and what kind of difference they made. My motor has been bored .030” over and had a slightly hotter cam put in it, unfortunately that’s all the info I have on that. I’d read that the 906 heads with the bigger exhaust valves would cause a loss of compression and possibly hurt performance. Any info would be appreciated, thanks guys!
Larger exhaust valves than your stock heads and also a larger combustion chamber which will lower compression. 906 heads likely flow better as well.
If you are running the stock 413 valve covers they may not fit. Early valve covers were 4 bolt IIRC. The rocker arms and pushrods were different than later setups as well.
Doubtfull the better flowing ports of the 906 will make much difference on a very mild build. Loss of compression will seriously hurt torque.
Milling about .040 will get the compression back. mildly porting and install of 1.74 ex valve in your 413 heads might be a good option.
Thicker .040 head gasket will also hurt compression vs stock type steel shim gasket at .020.
Do you know what year your 413 is? How does it run now? Do you like it?
Do you know what heads are on it now? Do you have a photo of the end of the head?
It has newer pistons so could be it's lower compression already, not many choices on 413 pistons.
Loss of compression is real from closed chamber to open chamber is real, and not good.
I'd stay with closed chamber heads.
The 413 is a 1965, it runs well currently. I do like it, just wanting more power out of it and floating some ideas around. The heads I’m not sure, I’m hoping to get the casting number off them this week as the valve cover gaskets need to be changed anyways. I can try and get a photo of the end of the head. As far as I know they’re the heads that came on the motor originally.
Sounding like a pass in the 906 heads though. Maybe just an intake swap would give it something more. There’s hopefully a set of 4.10 gears going into it in the spring that should make it more interesting.
What carb is on there? Are the secondaries opening? Does it go full throttle?
What parts are bolted to this engine?
How high of RPM will it make power?
Gears are #1 to improve performance. camshaft, carb, intake
1965 413 would have 6-bolt valve covers. A change to steeper gears will give you the best "seat-of-the -pants" performance improvement feel. Maybe upgrade to Edelbrock intake and 750 cfm. carb. Hard to guess what your current compression ratio actually is, but a change to "906" or other open chamber head will drop it a full point. I have open chamber "452" heads on the 440 in my '64 Polara. They are similar to a "906", but have the bonus of hardened exhaust seats. I feel the lower compression with a good open chamber head makes it easier to deal with today's crappy fuel, without pre-detonation. With high compression and poor fuel, you are forced to retard ignition timing to avoid "pinging". There could be a bigger power loss here, than with open chamber heads with better porting and larger valves.
It’s got a 650 summit on there now, I took it for a drive this afternoon and it did seem to feel a bit flat at full throttle, but with the 3.23 in the rear on the highway it does seem to get up and go still at 2700rpm. Parts wise nothing crazy, it’s got a 360 offenhauser intake on it that I’m gonna change out with the 650 summit and a set of hedman headers.
It does have 6 bolt valve covers on it. I think I’ll steer clear of the 906 heads. I was looking at putting an rpm intake on it. Same guy with the 906 heads has an aluminum high rise with a Holley double pumper as well he’s looking to move. No other details on those at the moment though.
Thanks for all the info everyone, this community is great!
That offy 360 is not good for perfoemanc, swap it out. Look at a 750 AVS2 carb.
I have been told that, I’ll take a look at that carb. Car currently has 2.25” exhaust on it as well that I’m thinking about changing to 2.5” when I get rid of the glass pak mufflers that are on it. Figured that couldn’t hurt either.
Another question, what is typically a safe redline for these 413’s? I realize that would be subjective to what’s been done to them internally.
Had a 65 413 in my 70 4-speed roadrunner...mild port original 516 heads, 484 purple cam, 1.74 exhaust valves, Edelbrock performer rpm intake. Bone stock original bottom end, standard bore. 3:55 gears. I once blew the clutch to pieces, and the engine went to suicidal RPM...and never missed a beat. 413s are tough, good engines. I still run that engine occasionally as a mule. Great street engine. Nobody knew it wasn't a 440.
You were happy with the rpm intake?
Offy 360 intake gives up a BUNCH of torque, especially as compared to the factory intake and even more so than any modern dual plane intakes - the Edelbrock RPM is the gold standard for dual plane intakes but it is taller than the offy. 750 will definitely help it breath too. Is the ignition in serviceable condition? Is it advanced sufficiently? I ask as there's often power on table with optimization there.
Increasing the exhaust diameter may help a little bit, but decent headers on any RB engine will certainly wake it up far more for the $$ spent.
413's can easily rev to 5,500-6,000, but there's not as much power up there with a mild cam so no real reason to go there. Lots of stories out there of people running them to 6,500 regularly and they seem to hold up fine if the valvetrain is stable and oil pressure holds, but it's not recommended to do it daily.
with a mostly stock build it won't make much power over 5200 rpms. the good thing about 413-440 they make their power down low. with 410 gears it will defeat the purpose. highway driving it will be at high rpms and not very pleasant. yes the only intake worth putting on is the rpm performer.
With what you have now and then add a better intake and a little more cfm carb.
Just me but if would go to a intake that will mate up with a good Thermoquad carb.
A edelbrock preformer will match up and fit the rpm range your at.
Keep the 3.23s but mabey drop a inch of diameter off the tires next purchase.
Get that carb , distributor ( spring kit )and cam all hitting stride at the same rpm.
Free up the exhaust.
To me a good tune is the 1st step.
I have the 906 heads on a 413, bored .060 over, with an Edelbrock Performer intake, Carter 750cfm, mild purple shaft cam, and 3.23 gears. It runs well with good stop light to stop light power and smoke up the tires all day long, while still having highway drivability. I really want to throw a Thermoquad on it for a test and see how it performs.
Ordered an rpm intake for it, hopefully have it installed by next weekends shows. It’s got a pertronix ignition on it, not sure on the timing though. Something to look into. The old sunpro tach has a redline at 4,200 so I didn’t want to rev over that without some more info, not looking to hurt the motor if I can avoid it.
So you think 4.10 gears would be a bad idea? Not too worried about highway driving at the moment, just looking to blast it from light to light. At some point in the future it will likely get an overdrive put in it.
