906 heads on a 413
413Polara
1:36 AM
Kingston Ontario
Have a line on a set of 906 heads for my 413. Wondering if anyone here has had a set on a 413 themselves and what kind of difference they made. My motor has been bored .030” over and had a slightly hotter cam put in it, unfortunately that’s all the info I have on that. I’d read that the 906 heads with the bigger exhaust valves would cause a loss of compression and possibly hurt performance. Any info would be appreciated, thanks guys!
Larger exhaust valves than your stock heads and also a larger combustion chamber which will lower compression. 906 heads likely flow better as well.
If you are running the stock 413 valve covers they may not fit. Early valve covers were 4 bolt IIRC. The rocker arms and pushrods were different than later setups as well.
Doubtfull the better flowing ports of the 906 will make much difference on a very mild build. Loss of compression will seriously hurt torque.
Milling about .040 will get the compression back. mildly porting and install of 1.74 ex valve in your 413 heads might be a good option.
Thicker .040 head gasket will also hurt compression vs stock type steel shim gasket at .020.
Do you know what year your 413 is? How does it run now? Do you like it?
Do you know what heads are on it now? Do you have a photo of the end of the head?
It has newer pistons so could be it's lower compression already, not many choices on 413 pistons.
Loss of compression is real from closed chamber to open chamber is real, and not good.
I'd stay with closed chamber heads.
The 413 is a 1965, it runs well currently. I do like it, just wanting more power out of it and floating some ideas around. The heads I’m not sure, I’m hoping to get the casting number off them this week as the valve cover gaskets need to be changed anyways. I can try and get a photo of the end of the head. As far as I know they’re the heads that came on the motor originally.
Sounding like a pass in the 906 heads though. Maybe just an intake swap would give it something more. There’s hopefully a set of 4.10 gears going into it in the spring that should make it more interesting.
What carb is on there? Are the secondaries opening? Does it go full throttle?
What parts are bolted to this engine?
How high of RPM will it make power?
Gears are #1 to improve performance. camshaft, carb, intake
1965 413 would have 6-bolt valve covers. A change to steeper gears will give you the best "seat-of-the -pants" performance improvement feel. Maybe upgrade to Edelbrock intake and 750 cfm. carb. Hard to guess what your current compression ratio actually is, but a change to "906" or other open chamber head will drop it a full point. I have open chamber "452" heads on the 440 in my '64 Polara. They are similar to a "906", but have the bonus of hardened exhaust seats. I feel the lower compression with a good open chamber head makes it easier to deal with today's crappy fuel, without pre-detonation. With high compression and poor fuel, you are forced to retard ignition timing to avoid "pinging". There could be a bigger power loss here, than with open chamber heads with better porting and larger valves.
It’s got a 650 summit on there now, I took it for a drive this afternoon and it did seem to feel a bit flat at full throttle, but with the 3.23 in the rear on the highway it does seem to get up and go still at 2700rpm. Parts wise nothing crazy, it’s got a 360 offenhauser intake on it that I’m gonna change out with the 650 summit and a set of hedman headers.
It does have 6 bolt valve covers on it. I think I’ll steer clear of the 906 heads. I was looking at putting an rpm intake on it. Same guy with the 906 heads has an aluminum high rise with a Holley double pumper as well he’s looking to move. No other details on those at the moment though.
Thanks for all the info everyone, this community is great!
That offy 360 is not good for perfoemanc, swap it out. Look at a 750 AVS2 carb.
I have been told that, I’ll take a look at that carb. Car currently has 2.25” exhaust on it as well that I’m thinking about changing to 2.5” when I get rid of the glass pak mufflers that are on it. Figured that couldn’t hurt either.
Another question, what is typically a safe redline for these 413’s? I realize that would be subjective to what’s been done to them internally.
Had a 65 413 in my 70 4-speed roadrunner...mild port original 516 heads, 484 purple cam, 1.74 exhaust valves, Edelbrock performer rpm intake. Bone stock original bottom end, standard bore. 3:55 gears. I once blew the clutch to pieces, and the engine went to suicidal RPM...and never missed a beat. 413s are tough, good engines. I still run that engine occasionally as a mule. Great street engine. Nobody knew it wasn't a 440.
You were happy with the rpm intake?
