Lower Control Arm Variations: Different Manufacturers or Body Style Differences?
Yennes
1:01 PM
Mülheim an der Ruhr, Germany
Hi everyone
while working on my lower control arms I noticed something interesting and I’d like to get your opinions. In the pictures you can see two arms side by side. The one on the left has already been glass bead blasted while the one on the right is still in unrestored condition.
What caught my attention is that the plate with the mounting surface for the rubber bump stop is made differently. On the right arm which has not yet been blasted the plate is noticeably wider and looks like some kind of pressed-in construction without welds. On the left arm which has been blasted the plate is narrower and clearly welded to the control arm.
Since I have already found pictures of both versions on the internet I don’t think anyone has messed with these parts. My question now is whether there were different manufacturers for these control arms or if this might be an A B and C Body difference that shows up in this plate design.
Maybe someone here has some experience or background info on this.
Yannik
What you have circled is the mounting surface for the rubber bump stop.
And its also the last item to resist the two LCA halves from separating longitudinally as they encircle the TB adjuster pivot point. The needed resistance is minor based on proven millions of cars driving billions? of miles without an issue. However, that does prevent the OC crowd from adding LCA bottom reinforcement plates with only being able to share their strongest reason for the added plate being "it can't hurt" :lol::luvplace:
Do I miss something?
I am asking if different pairs of LCAs existing. The two I am showing have different plates installed and I wonder if there were two manufacturers or something. This thread isn’t about to ask how to reinforce these LCAs.
What you missed in my response was your original question has no real structural significance even if you mislabeled it if there was any doubt, and I supported by example, and now you can focus on whatever else you might find important, as it is a free country. Different pairs can exist because of evolving structural/manufacturing improvements due to better designs or shortcomings discovered thru use, and those aspects can be removed from your concern of why the pair does not match, IMO.
They could have had more than one supplier, and or, small changes were made in the manufacturing process. A B and C bodies all had different lower control arms, so it is not that.
So it could be that this pair is from two different body styles, right? I never paid attention to this.
The different A-B-C-E body/Chassis designs all used LCAs unique to each letter EXCEPT....The B and E physically could be interchanged.
In short, the A body arms looked flat across the bottom for a short section like so:
The B and E bodies are curved all along the bottom edges.
Again, A body:
The C body LCAs are longer and have a torsion bar hex socket that is larger.
What may have happened is that a prior owner replaced one LCA on your car with one from another year model OR from a different assembly plant.
Again, A body:
Thank you for your helpful answer and visualization. I also think that someone must have swapped an LCA at some point. I also had in the back of my mind that A and B-body LCAs are different, and that B and E-body are the same. And I had already considered the possibility that there might have been different suppliers.
It seems weird but the A body LCA is actually longer than the B by about half an inch. Yeah, the smaller cars got a slightly longer LCA.
The LCAs you posted up have identical sway bar mounting tabs so they are specifically 1966-1969 style. Over that time, there may have been a mid year change or as mentioned, one LCA could have come from a different car made in a different assembly plant.
Good luck to you.
B body arms have an RS stamping. A body have a VL stamping. The shock mounting holes are further inward on an A body arm.
And the A body LCA arms are longer but the shock mounting points are closer to center of the car?
That seems odd at face value.
Only reason I knew? Made the mistake of grabbing a pair that looked nice out of my stash. Blasted, painted and installed them when building my 64. Then realized the shocks wouldn’t bolt up. Then found the stamping lettering.
