themechanic
Oklahoma is OK
- 1:04 PM
- Nov 11, 2012
- Moore, Oklahoma
If the fuel gauge was linear it is easy to calculate but it's not.
That's what I said is correctly calculated assuming the gauge is linear. Correct me if I'm wrong but isn't the gauge non-linear?Look up the capacity spec of whatever type of vehicle you have in mind and divide by 4.
I do not believe the sending unit rheostat is wired to accurately reflect the shape and volume of the tank at all levels. If it's a 16 gal tank, the last 5 gals might show as a quarter.That's what I said is correct assuming the gauge is linear. Correct me if I'm wrong but isn't the gauge non-linear. ?
Thanks for that, post #3 and 16 are the good take aways. Looks like they did try tailoring the winds to the changes in in volume/ height.
Bear in mind also that the float is in the deepest part of that shape of a tank. So 1/4 (which = approx 4.5 gallons) might show as a lot less than a quarter of a tank.
It also depends upon the stance of the car and whether or not the driver is in his/her/they/them seat.
As long as we're just throwing out numbers, I'm guessing, for a 19 gallon tank, it's more than the 6 gallons the A body owner posted jn the photo above."How many gallons in a 1/4 tank of gas?"
1/3 of what it takes to fill the tank?
That point was raised in the FABO thread.Unless a tank has consistent equal surface area of the fluid as it fills, the height of the fluid will never be a linear indicator in regard to fuel capacity of the tank. Unless the float/gauge is calibrated for any inconsistency in that fluid area, the gauge will never accurately be representative of the fluid contained, only likely just its height.
A typical A body tank does not meet this requirement.
And now it has been raised linearly in FBBO, and it applies to any tankThat point was raised in the FABO thread.
Are you certain, because gauge/wire resistance is determined by wire gauge, spacing, and length, all of which I can only guess at by mere observation.Fuel sender comparison. No idea what the OEM sender came out of but by the shape we can imagine the tank shape. The aftermarket sender would be accurate in a square tank. You get it.
18 gallon tank? A 1/4 would be 4 1/2 g. It should be moving towards 3/4 of a tank with 3 gallons gone.I'm curious how many gallons have to be out of a tank with a spectra unit before it drops below full.. i been paranoid about mine cause it seems to stay on full i went to throw $20 in but it only took 3 gallons and was full.. should the gauge of dropped at missing 3 gals?
