Casca2525
- 9:14 PM
- Mar 20, 2025
- Chesley, Ontario Canada
Well ima be busy for a while!
TY Bob
TY Bob
Ok I'll bite just because I'm 6 beers in and have nothing better to do at the moment.I have a job and a very good understanding of the ASTM listing of the various grades and alloys of the myriad of stainless steel available and their physical properties and limitations. Perhaps, you should take the time to learn about the different stainless alloys rather than criticize me for YOUR lack of knowledge and understanding. Call me any name you want....it comes down to what I know vs what you don't understand.......just my opinion.....
BOB RENTON
A "Gensel".....what an honor! (How about a worm?). Knowledge is NOT USELESS....unless you don't understand it and the only thing you can produce is a littany of words that typify your lack of understanding of the subject.......the fix......educate yourself rather than causing derrogrative statements....which does not denigrate my knowledge but just emphasizes your lack of understanding. Using obscene language to "emphasize" a position, does nothing but shows lack of vocabulary skills......relevancy??? But this is just my opinion.........your turn.......Ok I'll bite just because I'm 6 beers in and have nothing better to do at the moment.
I'm sure you do have a very good understanding of ASTM standards. Good for you.
We're talkin about a f@cking lower radiator hose spring for Christ's sake. The point is that any form of spring will give support to a hose from collapsing regardless of what it's made of. Stainless, whatever grade, is better than one made from soft steel, brass, aluminum, cardboard, plastic........
You know Bob, you are worse than a troll. You're a Gensel.
We all have read your over the top analysis, irrelevant posts, on this site for years. I see you as this shitbox of a person, sitting in a shack in the woods. A man who once thought he was relevant but now no longer is and feels he needs to flex useless knowledge in an effort to make himself feel relevant.
Can't wait to see your analysis of the term "Gensel".
Which would you recommend for a Mopar big block from that CJ pony website?One is for a big block (8”) and a small block (12”).
Last word, a gensel is actually a worm's worm. Lower than whale **** on the bottom of the sea. Check your research Dr. Science.A "Gensel".....what an honor! (How about a worm?). Knowledge is NOT USELESS....unless you don't understand it and the only thing you can produce is a littany of words that typify your lack of understanding of the subject.......the fix......educate yourself rather than causing derrogrative statements....which does not denigrate my knowledge but just emphasizes your lack of understanding. Using obscene language to "emphasize" a position, does nothing but shows lack of vocabulary skills......relevancy??? But this is just my opinion.........your turn.......
BOB RENTON
Grab a tape measure and make a decision. How long is your lower hose on your current configuration?Which would you recommend for a Mopar big block from that CJ pony website?
I bought the 12”, you can squish it in there if it’s too long.Which would you recommend for a Mopar big block from that CJ pony website?
I'm still flattered that the word is in your somewhat limited verbalizatiion skills. Btw...whale excrement is disbursed immediately after being discharged....old wives tale #5.....check your sources for accuracy.....Last word, a gensel is actually a worm's worm. Lower than whale **** on the bottom of the sea. Check your research Dr. Science.
BOB RENTON
Because I just posted a successful solution without trying to have a pissing match over what it’s made out of , thanks for thinking of me though, I knew someone would appreciate it!Why not the Amazon one in post 31
I guess for me its 2 for $30, cause I'm not paying $24 for 1 springBecause I just posted a successful solution without trying to have a pissing match over what it’s made out of , thanks for thinking of me though, I knew someone would appreciate it!
