2025 15th Annual FABO NHRA "Pick 'Em" Game - I Can't Wait!!!
The point reset protocol and special rules for the end-of-season 6-event "Countdown" was last posted during the 2024 "Pick 'Em" game. So, for both new NHRA "Pick 'Em" game players and those who forgot, here they are:
PLEASE NOTE SPECIAL "COUNTDOWN" GAME RULES (effective following the U.S. Nationals):
* The "pick carry over" is not in effect for the end-of-season 6-event "Countdown". You MUST either post picks for each event or "lock" your picks if you feel you may forget to post new event picks or you want to guard against your computer going down for any reason. Of course, you can always override your "locked" picks for any event or change your "locked" picks at any time.
* If your picks are currently "locked" then they will continue to be "locked". If your picks are not "locked" or they are "carry over" picks from previous events, then you MUST post picks for the next event and each following event in order to stay in the "Countdown" for the remainder of the 2025 NHRA season. Of course, you can post new picks for the first event of the "Countdown" and "lock" them.
* If you override your "locked" picks for a single event, your picks will revert back to the "locked" picks for the next event unless you post otherwise
* Following the completion of the U.S. Nationals I WILL NOT BE SENDING ANY REMINDERS TO POST PICKS FOR THE REMAINDER OF THE 2025 NHRA SEASON. To use a classic drag racing saying, "If you snooze, you lose"!
*If your picks are not "locked" and you fail to post picks for any event during the "Countdown", then you will be "parked" for the rest of the 2025 NHRA season with the points you have earned up to that time.
Here's how the game points will be re-set following the completion of the U.S. Nationals:
2000.0 - "Pick 'Em" game point leader after the U.S. Nationals
1970.0 - second place player unless the point separation from the first place position is less than 30 points. If you are only separated from the first place player by less than 30.0 points, then you will maintain that lower-than-30.0 point separation.
All player positions below the second place score will be separated by 10.0 points unless a player is less than 10 points from the player in the position in front of them. If you are only separated from the player immediately in front of you by less than 10.0 points, then you will maintain that lower-than-10.0 point separation.
Example:
In the 2019 game, '64BEL' (FBBO) was only 4.5 points behind the player in front of him so he started the "Countdown" separated by only 4.5 points.
By the way, the 30-point lead at the beginning of the "Countdown" is not insurmountable. In the 2019 game, the game leader following the U.S. Nationals had a 30.0 point lead at the beginning of the "Countdown", but did not win the game.
GOOD LUCK ALL!
71st annual Cornwell Quality Tools NHRA U.S. Nationals qualifying leaders (per nhra.com event 'Detailed Results'):
Q1
Weather: 66F, 59% relative humidity, barometer 30.08", adjusted altitude 1,718', track temp. n/aF
TF: Brittany Force, 3.666 @ 339.79
FC: Jack Beckman, 3.865 @ 332.26
PS: Greg Anderson, 6.491; Greg Anderson and Deric Kramer @ 210.44
PSM: Gaige Herrera, 6.739 @ 200.98
Q2
Weather: 71F, 52% relative humidity, barometer 30.13", adjusted altitude 2,022', track temp. n/a
PS: Greg Anderson, 6.491; Erica Enders @ 211.39
Q3
Weather: 76F, 50% relative humidity, barometer 30.09", adjusted altitude 2,400', track temp. n/a
PSM: Gaige Herrera, 6.739; Richard Gadson @ 201.01
Q4
Weather: 75F, 45% relative humidity, barometer 30.20", adjusted altitude 2,121', track temp. n/a
PSM: Gaige Herrera, 6.739; Jianna Everisto @ 201.73
Q5
Weather: 75F, 44% relative humidity, barometer 29.27", adjusted altitude 2,211', track temp. n/a
FC: Jack Beckman, 3.865; Austin Prock @ 333.00
Congratulations to 'TT5.9mag' (FABO) for winning the 2025 Cornwell Quality Tools NHRA U.S. Nationals Top Qualifier title with a PERFECT total of 32.0 bonus points. He correctly picked the #1 qualifier in Top Fuel, Funny Car, Pro Stock and Pro Stock Motorcycle.
'cuda20' (FABO) and 'johnnycuda' (FABO) were right behind with 30.5 bonus points.
'GTXDAN' was the highest FBBO qualifier with 30.0 bonus points.
More great picks!
We have 17 players this week and 12 different driver combos made up of:
* 6 different Top Fuel drivers with one Round 1 head-to-head matchup between #5 qualifier Antron Brown (1 pick) and #12 qualifier Justin Ashley (1 pick). There is also a possibility of one head-to-head matchup in Round 2 if both drivers survive.
* 4 different Funny Car drivers with no Round 1 head-to-head matchups. The earliest possibility of a head-to head matchup is in the semi-Final round of eliminations if both drivers survive.
* 3 different Pro Stock drivers with no Round 1 head-to-head matchups. The earliest possibility of a head-to-head matchup is in the semi-Final round if both drivers survive.
* 3 different Pro Stock Motorcycle drivers. The earliest possibility of a head-to-head matchup is in the semi-Final round of eliminations if both riders survive until then.
Good luck all!
We're racin Indy.
Congratulations to 'cuda20' (FABO) for winning the the "Top Picker Eliminator" title for the 71st annual Cornwell Quality Tools NHRA U.S. Nationals with an outstanding total of 255.5 points. He picked the class winners in Funny Car, Pro Stock and Pro Stock Motorcycle. His Top Fuel pick lost in the second round of eliminations. He was also helped with ET bonus points in Top Fuel and Pro Stock Motorcycle, Speed bonus points in Pro Stock, and bonus points for a new National Record for Speed in Top Fuel.
'64BEL' (FBBO) grabbed the runner-up spot with 231.0 points.
Way to go!
Here's where the bonus points were earned if you picked the right drivers:
Top Fuel
E.T. - Brittany Force, 3.666 during qualifying
Speed - Brittany Force, 343.51 (new National Record) during Round 1 of eliminations
Funny Car
E.T. - Jack Beckman, 3.865 during qualifying
Speed - Bob Tasca III, 337.24 during Round 1 of eliminations
Pro Stock
E.T. - Greg Anderson, 6.491 during qualifying
Speed - Erica Enders, 211.39 during qualifying
E.T. - Gaige Herrera, 6.738 during qualifying
Speed - Jianna Everisto, 201.73 during qualifying
Congratulations to 'stroked340' (FABO) for being the NHRA "Pick 'Em" game point leader at the close of the regular season!
Here are the game point standings after the 14th event of the 2024 season:
1710.5 - stroked340 (FABO) no change in game standings
1700.0 - alsant (FBBO) +1
1665.0 - GTXDAN (FBBO) -1
1661.0 - TT509mag (FABO) no change
1626.0 - ocdart (FABO) no change
1619.5 - 64BEL (FBBO) +1
1600.0 - Budnicks (FBBO) -1
1488.5 - johnnycuda (FABO) no change
1466.0 - Back in Time (FABO) no change
1455.0 - cuda20 (FABO) +1
1429.5 - Yunick13 (FABO) -1
1383.0 - memike (FABO) no change
1360.5 - Outlawd (FBBO) no change
1045.0 - Nick2317 (FBBO) no change
924.0 - Moms Duster (FABO) no change
172.5 - 62Dodge_ (FBBO) new player
170.5 - Pecos Bill (FBBO) new player
Surprisingly, not a lot of position movement even with the points-and-a-half for elimination round wins at the U.S. Nationals.
Now we get a weekend off to study our picks before the first event of the six-race "countdown".
The next race event on the 2025 season will be the 40th annual Reading NHRA Nationals at Maple Grove Raceway in Mohnton, PA, scheduled for September 11-14.
nhra.com currently shows the following class entry numbers:
14 - Top Fuel
18 - Funny Car
17 - Pro Stock
13 - Pro Stock Motocycle
As always, please check to verify your picks are participating before posting your picks.
GOOD LUCK!
The "pick 'Em" game points reset after the U.S. Nationals per post #301. I will post the reset point totals in the next day or two so be on the lookout.
Following are the re-set 2025 NHRA "Pick 'Em" game points:
2000.0 - stroked340 (FABO)
1989.5 - alsant (FBBO)
1979.5 - GTXDAN (FBBO)
1975.5 - TT5.9mag (FABO)
1965.5 - ocdart (FABO)
1959.0 - 64BEL (FBBO)
1949.0 - Budnicks (FBBO)
1939.0 - johnnycuda (FABO)
1929.0 - Back in Time (FABO)
1919.0 - cuda20 (FABO)
1909.0 - Yunick13 (FABO)
1899.0 - memike (FABO)
1889.0 - Outlawd (FBBO)
1879.0 - Nick2317 (FBBO)
1869.0 - Moms Duster (FABO)
1859.0 - 62Dodge_ (FBBO) new player
1857.0 - Pecos Bill (FBBO) new player
The point spread difference over the top 15 players before the re-set was 786.5 points. Now, it's only 131.0 points.
This is still anybody's game and it's going to be exciting with a lot of position movement over the six-race Countdown.
Our two new FBBO players are going to have an impact.
PLEASE don't forget to post your picks before the start of qualifying for each Countdown race if you do not have "locked" picks!
There are no pick carryovers and there will not be any reminders to post your picks for the remainder of the game.
PLEASE REVIEW THE SPECIAL "COUNTDOWN" GAME RULES SHOWN IN POST #294 MARKED WITH A "*"
GOOD LUCK ALL!
Howdy Hooray I'm not last, now with the playoffs on, just spit balling here are first thought of champs TF Stewart, FC Prock, PS Enders, PSM M. Smith, Factory Stock Showdown Pawuk. Two are wishful/hopeful thinking.
@ocdart
please change my 'locked in pick' from T/F
from A. Brown
to Tony Stewart NOW, please
the others I can live with
just some talking smack
I had 2 winners, F/C & P/SM
Antron Brown let me down too much, I need a change, gave him all the chances I could
now watch he'll win now :BangHead:
I was surprised P/S G. Anderson blew off the tires, out of the gate/early rds
he had everyone covered :BangHead:
I did like seeing KB/Titan team win
I hated seeing P/S Miss Piggy/Enders even in it, "Elite Team BS" :icon_fU:
she got handed a pass 2 of the 3 passes (only Greg Stanfield) seemed like gave her a run
& then let off at the stripe, all team BS rds
(sure seemed like it, shady ****) getting her into the finals
they all laid down or sat, I hate that team BS, run em'
Nice job Bel !
Back attcha, alsant!
Hey guys, we have 4 in the top 7. Lets bring it home 2 years in a row!
I hear you, Bud! I almost bailed out on Justin Ashley after the last few races, but he held me up this week. I am considering going with Dallas Glenn, though. I think he was my lock at the beginning of the year. But if I switch, Greg Anderson will surely punish me for it.
I knew Ashley was going to beat Tony, as Tony has never been faster than .050 on the light, and I think Ashley had an average of .034 on his previous rounds. It was still good to see him make the final. It was 60 degrees when the first round started at 10:00 am. They said the weather conditions were better than Friday night, that's why Brittany was able to lay down that big number. They just keep beating themselves because they go lay down a big number then come back and can't get down the track the next round or so. I don't know if they showed it on TV but there was a lot of lane swapping going on in both fuel classes and pro stock too. Somebody wouldn't make it down the track and the next pair would change lanes.
The turn out was down for some reason as the bleachers where I sat (pit side) was only about half full. The other side is all reserved seats and it hasn't been full in 10 years at least. I don't know if they showed what Cornwell tools did for all the other winners but it was pretty cool. They had one of those huge tool boxes full of tools ($17,000 said value) that they gave away to one of the other class winners. They have a small stage set up in front of the bleachers and gather all the other class winners to introduce them to everybody. When they went up on the stage they selected a new box set of screw drivers and took with them onstage. They opened the box and if it contained a certificate for the tool box they won it.
I've been to a lot of races between Nascar and NHRA and that's the first time I've ever seen an AWACS plane do a fly over. Kind of different but still cool.
Just in case any players with "locked" picks may have forgotten who they have "locked", here is a list of what my records show:
alsant (FBBO)
TF Tony Stewart
FC Austin Prock
PS Dallas Glenn
PSM Gaige Herrera
64BEL (FBBO)
TF Justin Ashley
FC Austin Prock
PS Greg Anderson
PSM Gaige Herrera
Budnicks (FBBO)
TF Antron Brown
FC Austin Prock
PS Greg Anderson
PSM Gaige Herrera
cuda20 (FABO)
TF Brittany Force
FC Austin Prock
PS Erica Enders
PSM Gaige Herrera
johnnycuda (FABO)
TF Brittany Force
FC Austin Prock
PS Greg Anderson
PSM Matt Smith
MomsDuster (FABO)
TF Clay Millican
FC Spencer Hyde
PS Erica Enders
PSM Gaige Herrera
Nick2317 (FBBO)
TF Brittany Force
FC Matt Hagan
PS Erica Enders
PSM Matt Smith
Yunick13 (FABO)
TF Brittany Force
FC Ron Capps
PS Erica Enders
PSM Gaige Herrera
If you are not listed above, then I do not have "locked" picks for you and you must post updated picks before each upcoming race in the 6-race Countdown.
@ocdart
from A. Brown
Done
Great day All
Here are my guesses
TF-Force also top speed
FC-Hagen
PS- Enders
PSM- M Smith
