RV2 reman or Sanden conversion
fourgearsavoy
3:22 AM
Rittman Ohio
Got a customer with a leaking RV2 compressor and he was asking me if it would be better off in the long run to do the Sanden conversion. He is not concerned about originality he just wants cold air that will last past the next generation with his grandchildren.
Car is a 67 Chrysler 300 rag, 440 mill.
Thank You
Gus
Thank You
Gus
What is "leaking"??? The carbon vs ceramic shaft seal is an easy fix. There are rebuild kits offered on line to rebuild the entire unit.....gaskets, and valves, etc, internal parts. No adapting brackets or hoses required.....repair the RV2 UNIT.......just my opinion.....
BOB RENTON
BOB RENTON
Don't know yet this is just something one of his buddies told him. He's bringing it by the shop this weekend so I can give it a proper diagnosis.
I rehabbed my system a couple years ago and fixed a poorly done 134a conversion. I’ve been waiting for the compressor seal to go since it was only thing I didn’t change. So far so good anyway. Most guys have told me how tough the RV2 is, the seal is a bit of a weak link as it was never intended for the higher pressures of 134. Everyone says the seal is easy to change out.
I’ve had my V2 rebuilt it was under 300 to have it done .. I’ll go R12 with it but I’ve done 134A with no problems ..
If he wants cold, better stick with R12!
I installed a new under dash unit in this car about 10 years ago and it's been cold until this very hot summer. I replaced the condenser, drier ,and flushed the system when I put the R134 in it.
BOB RENTON
Update ! got the car in on Saturday and all that is leaking is the gasket on discharge port of the compressor. Now I just need to order the gasket. Seen a few on the net, some steel and some composite. Any preference on what gasket to use?
