1967bperko
- 8:37 AM
- May 15, 2024
- jefferson township pa.
Last fall I was advised to put waterless coolant into my 1967 383 four barrel Chargers engine after installing a new Aluminum large tube radiator.Not long after that one of my cylinder heads got a crack.I’ve since been reading various articles that are supportive of using the waterless coolant because of it’s higher boiling point, and other articles that say waterless coolant can make your engines heads much hotter than with a 50/50 mix.Well over this past weekend I finally decided to get that waterless stuff out of my entire cooling system. I thoroughly drained and flushed the cooling system 3 times to insure that all of the waterless coolant was completely out of the entire cooling system. I put in all new 50/50 in the system and drove the car to a local car show and back, the factory temperature gauge stayed at a much more normal level than it did running the waterless coolant . This was a lesson learned , that and I wanted to share it with all the those who are considering running the waterless stuff in a stock Mopar street machine.
