zombezoo
Update:
It finally cooled off here (mid 70s) enough to work on the car.
I made two changes:
1) I swapped back to my recurved distributor. Before the head swap, I had trouble fouling plugs and poor running and the engine seemed to like the factory RV distributor better. Now with the fresh heads, the recurve unit works better. This did help slow the creeping temps down significantly. I still had a problem with 30min+ runs over 70mph reaching 220 degrees.
2) I pulled the AC Condenser (currently in-op) and found some leaves and trash between the radiator and the condenser. Maybe blocking the middle/bottom of the radiator, maybe 5% of the area. I blew out the radiator from the engine side, left the condenser out and went for a drive. It now does not get hotter than 206 (Robertshaw 370-180 stat).
For reference: 206 on the CTS has the 73 factory rally gauge just overlapping the right side of the operating temp line on the "C" side of the gauge.
Anyone ever check how much temperature drop they get across their radiator core?
Radiator is a re-cored Factory 3673054 26in radiator, I'm only seeing about a 25 degree (165-140ish after pulling over from highway speeds where engine is 206) drop from top hose to bottom? I'm trying to understand what's happening. When driving around local roads at 45mph and below, temps are 195 on the CTS mounted in one of the plugs near the heater hose connections. When I get on the highway, it very slowly creeps up to 206 over the course of like 30 minutes of driving 70+.
Temps fall back to 195 shortly after exiting the highway. Either idling or slowing down to speeds below 50pmh.
Is this because the thermostat is restricting flow because temps are nearing the opening temp (195 degree temp on a 180 stat)?
This all makes me think the system is barely keeping up with the heat being generated at speed. Engine spins roughly 3000rpm at 70mph.
I still need to gather a bit more data but wanted to get this temp drop question out in case anyone has input here.
I made two changes:
