Bought a 70
Just found a 70 F383HP block to start mine as well. What made you choose that kit? If you have a build plan I would like to follow it and see what other parts you choose. Ths is my first build.
I like a fast revving engine and I plan on running exhaust manifolds so anything larger would have been a waste. Basic plan is about 10-1 compression with 440 Source heads, roller rockers, solid roller cam, we have not chose the cam yet. DP4B intake, AVS2 800 carb, TTI 2-1/2 full exhaust.
The wiper motor came in today from Topher, thing is a work of art. It was literally falling apart when I gave it to him at Carlisle. I also got a correct am radio that will get a modern AM/FM conversion.
got the Challenger on the spinner and shop rearranged....I'm chomping at the bit to play with frame connectors, but I have a series of loose ends that need to be tied up first..... I got the ends of the dutchman roughed in..... I needed to cut the drip rails, or work around them (butcher the 1/4s) when installing the quarters; so I cut them, of course; dealing with that first..... Bottom of the trunk latch support to the trunk floor needs a little fab. rear bumper reinforcement plates need to be reinstalled.....boring, I know...... more pics coming
the process continues..... I'd have it all snapped up tight, but the new clips are loose and need to be pulled out and bent a little. I called it a day :drinks:
Pics of the finished radio. Nice job as always. Polished up the lens real nice.
time for something a little different..... frame connectors
got 'em fitting nice and tight, makes for easier welding........knocking things off the never ending list
I'll weld up them enough to make the car rigid, and finish up on the rotisserie
