Coelacanth
- 11:35 AM
- May 10, 2024
- Edmonton, Alberta, Canada
I have my instrument panel out, it's fixed and cleaned up/restored as good as possible. While it was out, I had a good look at the wiring under the dash, and spent a good couple hours following FSM info and a color wiring schematic I had to identify any potential wire issues. There are some obvious connectors with no mates as my car lacks the center speaker, currently has no stereo, there's a connector on the steering column for a cruise control I never had, and probably a connector for A/C, which I never had.
That said, I found a few mysteries that hopefully someone can help me unravel.
My car used to have an alarm system that was long ago removed. I also have removed all the wiring to the stereo and speakers I used to have. But these 3 mysteries have me confused.
This 3-spade connector with parallel-aligned spades has no mate anywhere. Looking at the yellow, yellow w/brown tracer, red and grey (?) wires, does anybody know what this might've been used for?
This single-spade yellow wire hanging off what I believe is the delay-relay, with yellow and pink wires...what might this connect to, if anything?
And lastly, this purple wire hanging loose from the brake switch, where it was spliced into one of the pink wires. This definitely doesn't look original. Any clues what it might've been used for, and more importantly, is it no longer needed, for a car with now-all-original wiring?
Back in the 80's, I did a bit of hacksawing to not only install a pull-out stereo (the whole stereo pulled out back in those days, not just the faceplate) but hide it behind a removable section of the black plastic center dash piece. It was pretty cool back then, if I do say so myself. If a thief were to peek into the car, he'd see no stereo at all. I decided to do this after a thief broke into the car and, in trying to remove an earlier pull-out stereo chassis that was empty (the stereo wasn't even in the car), did his own butcher job ripping the chassis out of the dash.
