That’s what I thought, nice rim.It was a joke. The caliper does fit under this rim -
I've never touched the strut rods but the paint is worn off the frame rails behind the suspension on both sides.
See post #88. You can see the red paint gone but some original green paint remaining.
Toe out in turns
We do. Put the car together and drive it.Mine might hit in the back first too when the suspension's aligned.
Thanks for your contributions, KD. (Not being ironic)
I'd think we'd all be seeing the same thing - and we might, when everything is adjusted on my car.
Not with me, not ever. I've always had some toe in.Toe out in turns
Would that be an anti- Ackerman angle? Or reverse/ negative ? You got me on that one.Not with me, not ever. I've always had some toe in.
You are over complicating things.Would that be an anti- Ackerman angle? Or reverse/ negative ? You got me on that one.
Not at all. I was trying to explain for JR why the rear of the tire will hit the frame rail.You are over complicating things.
Simply put, my tires contact the frame rail behind the tire on each side while never contacting any other part of the car. When I used to pay for alignments, I specified 1/8" toe IN. That is what I set it to when I aligned it the last time.
My 2007 Dodge truck is the opposite. The tires rub the front sway bar but nothing else.
