JeffreyMopar
Hello All,
I was driving my 70 Superbee and after stalling at a light I noticed a noise between a click and small knock to the engine not super loud but noticeable like a bad rocker or small knock.
compression Tested all 8 cylinders and all but lovely #6 are performing at minimum 130 psi. #6 is hitting 60 psi at best. #6 spark plug was also wet and oily unlike the rest a bit more dry.
Is this a blown head gasket issue or more? I have only test compression and changed oil. No signs of metal shavings in oil change.
